M76 Posted February 25, 2010 Share Posted February 25, 2010 Hi I have a dwg drawing which has some kind of an error, which prevents some topology operations to run on it in map3d. I've tried exporting to v12 dxf, even to microstation dgn, but the problem still exists. Is there an utility that can clean a drawing file from any non-standard entries, or anthing that can cause problems? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted February 25, 2010 Share Posted February 25, 2010 Have you tried PURGE and AUDIT? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2010 Share Posted February 25, 2010 You may have to resort to the command line version of the Purge command so you can also delete any non-referenced regapps. Type it as follows: -purge. Quote Link to comment Share on other sites More sharing options...
M76 Posted February 26, 2010 Author Share Posted February 26, 2010 Thanks, that didn't do the trick, audit found no errors, purge found some zero length objects but that didn't solve the problem. Quote Link to comment Share on other sites More sharing options...
NBC Posted February 26, 2010 Share Posted February 26, 2010 how about WBLOCKing it out to a new file ? Quote Link to comment Share on other sites More sharing options...
M76 Posted February 26, 2010 Author Share Posted February 26, 2010 doesn't work either I cut the drawing in half, outputting about half of the objects to one drawing and the rest to another. And it works flawlessly on both of them. But if I merge the two halves together the problem is there again. and its not because the drawing file is too big, the routine works on files five times bigger than this one. Quote Link to comment Share on other sites More sharing options...
