Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    peterg's Computer Details
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    41
    Default How do I convert lines/arcs to polyline
    Using PEDIT how do I convert a number of lines & arcs into a polyline?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,138
    Select the option to "join" then choose which lines and arcs (ends must be touching) you wish to join up. If the operation is successful your multiple lines and arcs will be become one entity.
    Full Member
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    41
    PEDIT
    polyline or multiple multiple
    select objects lines selected
    enter an option which one do I select
    enter fuzz distance or joint type ?
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,015
    Code:
    Command: pe
    PEDIT Select polyline or [Multiple]: m
    Select objects: Specify opposite corner: 8 found
    Select objects:
    Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
    Join Type = Extend
    Enter fuzz distance or [Jointype] <0.0000>:
    7 segments added to polyline
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  5. #5
    Full Member
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    41
    Quote Originally Posted by alanjt View Post
    Code:
    Command: pe
    Select objects:
    Join Type = Extend
    I have tried this several times, but all the lines and arcs are still seperate lines & arcs, not one complete poly line is there something missing?????
  6. #6
    Civil 3D 2011
    Apr 2008
    6,015
    Quote Originally Posted by peterg View Post
    Do they all have different elevations? You can't PEdit>Join lines on different elevation planes.
  7. #7
    Full Member
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    41
    I am drawing in the isometric grid, all the lines are in the same plane at the same height.
    basically i have plotted 4 circles, drawn tangent lines from circle to circle & trimmed the circles to end up with a rectangle with radius corners.
    hope this describes it ok
  8. #8
    Full Member
    XP PRO
    AutoCAD 2007
    Jan 2010
    Liverpool, England
    41
    Code:
    Command: pe
    Select objects:
    Join Type = Extend
    After I press enter at this point, my command line says
    0 segments added to polyline
    please see where I have added red text.
  9. #9
    Super Member
    AutoCAD pre 2000
    Nov 2008
    578
    They pretty well got the thing nailed down. But only thing I can think of is if you somehow got double lines. An out and back situation. The arc or line will then easier connect into the second line than to connect up the next line in a series. Thus you actually then are trying to connect in a line into the middle of one section, or you may be trying to connect in a rectangle to the figure. In either situation, it can't be done.
    Wm.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,138
    Why not try drawing the rectangle first (remember to use OSnaps) then fillet the corners?
  1. TXTEXP does not convert text in to Lines and arcs
    By JONI in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Aug 2009, 04:33 am
  2. Convert multiline text to lines and arcs?
    By sharronjs in forum AutoCAD General
    Last Post: 16th Dec 2007, 01:34 am
  3. Convert a bunch of lines into a polyline
    By CADken in forum AutoCAD General
    Last Post: 14th Jun 2006, 02:15 pm
  4. Polyline - joining arcs and lines with widths
    By Snazzy D in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jan 2006, 10:00 pm
  5. Convert text to lines and arcs
    By Tim in forum AutoCAD General
    Last Post: 27th Sep 2005, 10:18 pm
