Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Junior Member
    AutoCAD 2010
    Feb 2010
    12
    Default Penn and Foster Structural Project Help
    Hi all, I am hoping somebody has experience with this and can provide some insight. I have completed the first plate successfully and now am attempting to draw the second which consists of an elevation (south). I am really confused with how the footing is supposed to be drawn. I cant completly understand the directions and have been trying to draw this for quite some time. I have attached a pdf for reference. I am having difficulties with the directions on page 11. Anybody have any suggestions or been through this before?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,134
    I swear this exact question has been posted here along with either an explanation and/or an image of the problem with the solution. Try a search on Penn Foster and see what that brings up.
    Junior Member
    AutoCAD 2010
    Feb 2010
    12
    Yea, I did a search before I posted this but it doesnt go into great detail nor provide illustrations, assuming we are talking about the same post.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,134
    Sorry about that. I was relying upon faulty memory chips. Must be time for an upgrade.
    Where is this PDF you refer to? For some reason I don't see it.
    Does it include the instructions as well?
    I notice you had some posts regarding Penn/Foster drawings back on the 7th and 8th of Feb. This is a different problem you're working on isn't it? Wasn't BigMike able to help you?
  5. #5
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    Education
    Car5858's Discipline Details
    Maint. Mech.
    Education
    Tutor, lab assisant
    AutoCAD 2010
    May 2009
    Hammond
    371
    Yes, the instructions are lacking a bit. I have helped Big Mike through the same problems. I do not know if the instructions have been changed since I took the course. Please attach a pdf of the instructions so that we can review them.
  6. #6
    Junior Member
    AutoCAD 2010
    Feb 2010
    12
    Sorry about that, I was sure it was attached...
    Anyways, I am having trouble right at the beginning of plate 2, page 11 I think. I have no idea what I am supposed to be drawing in regard to the footing/pillar. The way its described confuses me to no end. If there is any way to provide some sort of illustration of what is supposed to be drawn it would be so greatly appreciated.
    Thank you for all your help.
  7. #7
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    Education
    Maint. Mech.
    Education
    Tutor, lab assisant
    AutoCAD 2010
    May 2009
    Hammond
    371
    robxfinch
    Just like with plate 1, the instructions are scattered. You have to select what the draw order will be. Use construction lines to represent the elevations and label them, you will be removing the construction lines later. Think of the problem in question form,"What info do I need to draw this part?".
    Make sure you calculate the elevation footage correctly. The finish grade elevation is 292.90', make sure this is also drawn in the correct distance from 0', it will be checked when you submitt the drawing for grading. It also effects the drawing of the pillers correctly. You have to deduct the slab thickness. The bottom of the slab will be the top of the piller.
    In this plate (2), you are looking at the south elevation. Review plate one for the positions of the pillers and footing. You should have drawn them as a top view in plate 1, with the south elevation you will be drawing them with a front view. This is the long side of the building.
    Draw a center line at the piller locations. Looking at the top view of the piller it will be 16" each side. Divide 16/2 then offset the center line 8" to each side on the south elevation. Perform the instructions one sentance at a time. Keep track of what you are doing on your workflow/draw order sheet. The elevations determine the height of the footings and pillers. Remember that the pillers on the four corners of the building are different from the inside pillers.
    As much as I would like to provide you with a sample of the drawing; I am not able to comply. That would be cheating, this is one of the exam grades toward your certificate.
    Sometimes the instructions are confusing, that is to see if you are able to interpert the instructions correctly. It has been almost 2 years since I finished these drawings. Take your time and work carefully, do one thing at a time. Then check your work.
    The important thing to remember is that with Acad there are many different ways to acheive the same results.
    Just for your information, this same paragraph stumped 2 Cad designers that work for a friend of mine. I think I spent a few days figuring this one section out. The good part is that when you finely understand these instructions, you should be able to draw from instructions alone, if all the required information is included.
  8. #8
    Junior Member
    AutoCAD 2010
    Feb 2010
    12
    I will give it a shot in the morning. I am just having difficulty with what the actual footing is supposed to look like. Thanks for the help none the less.
  9. #9
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    Education
    Maint. Mech.
    Education
    Tutor, lab assisant
    AutoCAD 2010
    May 2009
    Hammond
    371
    I know it is sometimes hard to see the shape in your mind.
    Once you have the elevation drawn in, the dimensions are given on the footing. One of the elevations is the top of the footing.
    Subtract 4' from 292.90' this is the top of the footing.
    The footing dimensions are found on page 8;
    The dimensions of the concrete footings placed under all the steel columns are 16 x
    32 x32. The steel columns are centered over these footings.
    When you draw the footing, center on the column 4' below the finish grade. So this footing will be a rectaingle 16"h x 32"w.
    That help?
  10. #10
    Forum Newbie
    AutoCAD 2010
    May 2011
    5
    Default Help please
    Hi robxfinch,
    I am in the same boat that you where in... I'm trying to complete plate 2 and I'm struggling. what did you do to make it easier to understand?
    I wrote my thread before reading Car5858's breakdown clearly, I will give that a try. Thanks.
  1. Penn Foster Drafting with Autocad
    By sethtb1 in forum Student Project Questions
    Last Post: 27th Dec 2012, 05:02 pm
  2. Need Help with Penn & Foster exams
    By robxfinch in forum Student Project Questions
    Last Post: 13th Nov 2012, 08:14 pm
  3. penn foster autocad drawings help
    By mivshekwyo in forum Student Project Questions
    Last Post: 16th Aug 2010, 02:47 am
  4. Penn Foster Alumnae
    By BIGMIKE09281946 in forum Student Project Questions
    Last Post: 27th Sep 2009, 03:47 am
  5. Penn Foster Career School
    By acbunker in forum Student Project Questions
    Last Post: 29th May 2008, 05:11 pm
