I don't see why it would make a difference. There must be something else going on.
Hi,
I have a problem regarding with my standard block that i created on autocad 2009 64bits (windows vista operating system) when the dynamic blocks used on 32 bits OS the autocad will hang,error and closed with out saving the files,
i think there is a problem in the dynamic blocks that i created on 64bit OS, please if any one could help me and explain why i cannot used on 32bits OS.
Many thanks,
Yah Remark,
we try to insert the dynamic blocks in other drawing files no errors happened, only if we set the blocks on tool palletes as network sharing so that when i set the tool pallette it will set as same arrangement and blocks that i created on original pc (Autocad 2009 64 bit)
when they use the tool palletes that created blocks on 64 bit then come the error and automatically close the autocad 32 bits
On same autocad 64bit tool pallettes works fine.
