Results 1 to 8 of 8
    Senior Member
    not applicable
    Jan 2008
    Littleton Colorado USA
    166
    Default DWG TruView causes trouble - maybe
    I'm not sure where is the best place to post this. I just uninstalled DWG TruView less than a week after installing the latest version. I began having unexplained crashes of other software. TruView itself didn't crash. The reported errors were not helpful in tracking the cause. But after running a registry checker, it reported hundreds of errors, most of which referred to 'ACAD' this and that. I don't have AutoCad on this machine, but I have used TruView in the past to recover damaged files, change versions, etc. to use with other Cad/Cam programs. Anyway, after removing TruView and cleaning the registry, all is well. So I suspect, but cannot prove, that the latest version of TruView caused trouble on my machine (an aging Dell Precision 380 with 2 GB ram.)
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    What OS are you running?
    Senior Member
    not applicable
    Jan 2008
    166
    Win XP Pro Sp3
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    I see, well, the part that confuses me is that DWG TrueView never crashed but other programs did. Yet, you claim that when you removed DWG TrueView and cleaned the Registry (in that order, right?) everything works OK again.
    Now that the Registry has been cleaned create a Restore Point and reload DWG TrueView. What happens with your other programs?
  5. #5
    Senior Member
    not applicable
    Jan 2008
    166
    OK, when I have some time I'll do as you suggest and report back. And by the way, my OS is 32 bit.
  6. #6
    Senior Member
    not applicable
    Jan 2008
    166
    Probably a false alarm. I set a restore point. Ran a registry check - no errors. I downloaded DWG Trueview again. It installed (the default config) without incident or error. I restarted the machine. Ran a registry check - one error : invalid handler for extension - dwgtrueview standards checkfile. I did not fix this. Started Trueview and looked at a few drawings and did one recovery (actually a conversion - recover doesn't work - all explained in the Readme file - a minor PITA - my only complaint.) Closed Trueview. Ran all the major programs that I regularly use. Did get one crash, but it was of a familiar type with that software and I can't blame Trueview. Ran another registry check - one more error. It seemed to be related to the DirectX 9.0 that installs with Trueview. Not sure though. I let the checker fix those errors. I will monitor the system closely for a couple days. Thanks for the suggestion Remark. And thanks for your patience.
  7. #7
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,925
    Trueview uses net framework. It doesn't do a very good job of registering all of its values during the install. A lot of registry cleaners report orphaned keys with no values and delete them when they actually aren't. So after a clean up Trueview no longer works. And sometimes other apps that use it as well. After an uninstall, sometimes other .net program can fail as well. They should fix themselves but it might take a reboot or 2.
    So my advice for now is once you have trueview, you always have trueview! -David
    R12 (Dos) - A2K
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,052
    Only in one instance did I have a Registry cleaner (by Norton no less) get a bit too agressive. The result was an error when trying to boot into AutoCAD. Fortunately there was a fix for it that solved the problem. That's when I stopped using anything other than RegClean on any OS up until I made the switch to Win7. Not sure what I'll do now.
    Thanks for the update. Will keep fingers crossed that from here-on-out your computer doesn't crash any more.
  1. Trouble with an x-ref
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 25th Oct 2007, 12:25 pm
  2. SIN Trouble
    By MMS in forum AutoCAD Drawing Management & Output
    Last Post: 15th Mar 2007, 08:02 am
  3. MNU to CUI trouble!
    By MidKnight in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Aug 2006, 07:41 pm
  4. 3d trouble!
    By malavica in forum 3D Modelling
    Last Post: 13th Oct 2002, 09:14 pm
