Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Default Self-Intersecting Curve.
    When I try to extrude this closed polyline (yes it is closed) I get the message "Cannot sweep or extrude a self-intersecting curve." I do this sort of extrusion all the time (closed polylines with various geometry) and usually have no trouble.
    Can anyone shed some light as to why this is happening?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Sounds like you have some suspect geometry in your profile. Either redo the geometry or explode what you have and find the errant piece(s) and correct the situation.
    Senior Member
    AutoCAD 2004
    Sep 2004
    Oregon, Usa
    208
    Thats why I posted in...I spent a lot of time painstakingly checking every intersection to make sure there were no overlaps or shortfalls. I don't understand why "pedit" will close the polyline if there is a problem with the geometry?
    Usually when in "pedit" and you close bad geometry a line will form where you don't want one. In this case the closed polyline is the shape I need.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    I agree. That's what you and I would tend to think. AutoCAD, as it has demonstrated, thinks otherwise. What can I say? You don't have to convince me you have to convince AutoCAD. Draw it again.
    Maybe there's a stray bit of line somewhere?
  5. #5
    Senior Member Crazy J's Avatar
    Crazy J's Computer Details
    XP Professional, Version 2002 SP3
    HP Pavillion dv2000 laptop
    Genuine Intel CPU T1350 @ 1.86 GHz
    0.99 GB RAM
    Fujitsu MHV2080BH PL (80GB)
    laptop screen, additional Dell 10x13
    AutoCAD 2002
    Feb 2010
    Ohio
    157
    I can't see too closely, but is the object simply the four arcs and some straight line segments? If so, could you just try to draw a new pline, picking the same osnap points as you go? I would suppose that would work. It might not give you the root cause of your problem right away, but perhaps in the process you will figure something out about the cause... and it should get you going on what you are working on now.
    But then sometimes, if I know I worked around a bug but can't find what that bug actually was, it bothers me even more....
  6. #6
    0.99 GB RAM
    AutoCAD 2002
    Feb 2010
    Ohio
    157
    Default Presspull?
    Also, would this be a case where PRESSPULL could work? Don't have that command in my version, but I see a lot of uses for it in other posts. Just a thought.
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,118
    The only way for someone else to have a check is if you can post the drawing. My eyes are not good enough to see on your screen shot.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Not sure if the following may apply to your situation but someone inquired over at the AutoDesk Discussion Groups about overlapping polylines on the same plane causing problems. Bill Gilliss responded with a lisp routine that identifies the overlaps, creates regions, and zooms to the offending area in the drawing (pretty freakin' amazing if you ask me). He posted version 1.01 of his routine in the last post of the thread. The routine is named polylineoverlap.lsp in case you are interested.
    http://discussion.autodesk.com/forum...46499&#6346499
  9. #9
    Senior Member
    Glen Smith's Computer Details
    Win XP
    Dell Studio XPS 1645
    Intel i7 Q720 @ 1.6Ghz
    8 Gig
    Electrical 2010
    May 2008
    Cary, NC
    418
    I've had good luck using either BOUNDARY or REGION when AutoCAD and I differ on what a shape actually is.
    Glen
    “Progress isn't made by early risers. It's made by lazy men trying to find easier ways to do something." Lazarus Long in Time Enough For Love
  10. #10
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by Glen Smith View Post
    Glen
    Type BPoly and pick a point inside of the object.
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  1. Intersecting lines
    By Tyke in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2010, 09:49 am
  2. Intersecting lines
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Nov 2009, 02:04 am
  3. Polyline and Line intersecting
    By Jozi68 in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Sep 2009, 12:48 pm
  4. Isometric with two fillet intersecting
    By magwea in forum AutoCAD Beginners' Area
    Last Post: 14th Jan 2009, 10:34 am
  5. Fix self-intersecting pline boundary
    By ORgrown in forum AutoCAD General
    Last Post: 13th Dec 2006, 04:53 am
