Is it possible to change the color of a linetype?
Proctor
Hello: I'm working with Autocad 09 .net and wanted to know if there's a way to programatically change the color of a linetype? currently, i change the color of the object that is used in conjunction w/ the linetype e.g. spline (see pic). I started thinking about it, and wondered if the color could be changed for just the line type.
Thanks,
Proctor
QSELECT objects with the linetype and then use the PROPERTIES to change the colour of the selected objects.
Just one way of many.
nukecad: thanks for your response. But, isn't that essentially just changing the entity (e.g the spline like in my pic) rather then changing the color of the actual line type?
Thanks,
Proctor
Sorry I misunderstood what you were looking for.
We always set colour 'bylayer' here.
This again is not quite what you are looking for but could be a workround - make a layer with the same name as the linetype and put all of that linetype on the layer??
I don't think that you can set colour bylinetype other than changing the individual objects; There again I am restricted by using LT 2002 most of the time; Would be interesting to hear if anyone does know though.
Yea....I did have the linetype set on a layer at first but ran into an issue the users were having whereby they needed to have the same line type on a drawing use separate colors. I added code to change out just the color of the object e.g. the spline; however, then if they go to draw more using the line type, it reflects the color that the layer is drawn in, so I'm looking for alternative solutions.
Thanks again for your time and help. I'll keep this ticket open to see if anyone else has input.
Proctor
Lee Mac: in other words you are saying a line type has no color property - correct?
thanks,
proctor
I believe that is the case.
Correct.....
