Results 1 to 7 of 7
Thread: bevel gear
    Forum Newbie
    ishuka's Computer Details
    windows xp
    LG
    AutoCAD 2007
    Mar 2010
    philippines
    2
    Default bevel gear
    Need help, could someone teach me how to draw 3d bevel gear.
    thanks in advance!
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    If you are a student you can download Autodesk Inventor Professional for free. Inventor creates gears for you simply by filling in parameters in a dialog box (what are the parameters for your gear).
    Do you know how to create a spur gear in AutoCAD? (it is usual to start with a spur gear before moving on to more complex gears)
    If you must do in AutoCAD rather than Inventor it would be better with AutoCAD 2010 which allows parametric dimensions and constraints.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    windows xp
    LG
    AutoCAD 2007
    Mar 2010
    philippines
    2
    thanks, but how can i draw bevel gear on autocad ver.2007
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Do you really need the 3D model to be accurate? We just use to replace gears with cylinders (or cones in this case) and to worry about accuracy when we go to 2D drafting.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Quote Originally Posted by ishuka View Post
    Before I could begin to explain how to model a bevel gear I would need to know if you can model an easier spur gear.
    What is the purpose of the gear? Are you going to manufacture the gear or do you simply need something that looks good, but the actual gear will be purchased from a gear manufacturer.
    How much 3D experience do you have?
    Have you gone through the AutoCAD 2007 tutorials in my signature?
    Can you attach what you have attempted so far?
  6. #6
    Full Member
    AutoCAD 2007
    May 2010
    28
    Quote Originally Posted by JD Mather View Post
    hello,JD Mather
    I am trying to use the Inventor 2010 to design a bevel gear.Another problem is that i have to modelling an existed 2d dwg drawing bevel gear in the Inventor,but some parameters in the Inventor environment i cannot understand,the parameter "da_dvw",what is this prameter represent,can you explain this for me?3ks
    another question,is it possible in Inventor to export the parameter list into an Excel file?
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    You don't need most of the Gear Generator parameters.
    How much Gear design training have you had?
    Are you going to manufacture this gear or purchase from a gear vendor?
    How many teeth?
    Diametrial pitch?
    Pitch diameter?
    Pressure angle?
  1. Distributor Gear
    By ojh in forum Autodesk Inventor
    Last Post: 29th Jan 2009, 08:05 pm
  2. gear help
    By bolton78 in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2008, 10:08 pm
  3. Making a gear
    By phoenix12 in forum Autodesk Inventor
    Last Post: 5th May 2007, 12:27 am
