Results 1 to 4 of 4
    Forum Newbie
    not specified
    Jul 2005
    U.K.
    6
    Default .scr and autocad
    Hi
    How do I stop autocad from takeing over screen saver files.
    They have a .scr file extension and autocad belives this to be a script
    extension and takes it over, so when you open the propites dialog of a sreen saver
    it opens up as a notepad autocad sript??
    Senior Member Methuselah's Avatar
    Methuselah's Computer Details
    XP x64
    Mechanical
    Methuselah's Discipline Details
    HVAC Designer, BIM Technician
    Mechanical
    Revit MEP 2012
    Sep 2005
    Oklahoma City, OK
    284
    Ok, you have to reset the file association for the SCR extension.
    To do this, go to My Computer and click on Tools->Folder Options.
    Select the "file types" tab.
    Click "new".
    Type "SCR" into the box and then click "Advanced".
    It should show "AutoCAD script", if you change this to Screensaver it should fix your problem. If you want to open a AutoCAD script in notepad, you'll either have to use the "Open With" option under your right-click menu or just open the file from within notepad.
    Forum Newbie
    not specified
    Jul 2005
    U.K.
    6
    Hi
    Many thanks for speedy reply, worked just fine
    Bob
    Forum Newbie
    AutoCAD 2008
    May 2007
    1
    Hi, I know it's an old topic but I discovered another solution to this weird problem, perhaps it will be useful to someone
    recently after installing AC2008 the scr file extension was taken over by AC, although I fixed it like described above Autocad registred it back as a script files... this was very annoying becouse I use shortcuts to run screensavers and every time I started Autocad I had to fix the screensaver
    then on Autodesk Discussion Groups I found a post saying that this is the RegAcad17.dll file that registers file extensions, so I looked inside it and found that there are just strings, I found "s c r" starting at offset 1026Eh
    with a simple hexeditor I've changed it to "s s s" and now AC is no more stealing my screensavers and scripts can still be used but with a sss extension
