Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Forum Newbie
    AutoCAD 2000
    Mar 2010
    1
    Default Acad 2000 with Windows 7
    Hi
    I have installed Acad2000 on my laptop running under Windows 7 familial premium. I didn't use the install set up since it is a 16 bits application, I just copy all the file to my folder. Acad is running fine except that I can't use the DIM command, I received an unknown command message !!!! like for RECTANGLE, PROPERTIES.... it seem that some commands can't be recognize... is there a fix beside updating my Acad 2000 which is doing fine for what I need....
    Best regards
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,312
    Autocad 2000 is no longer supported by Autodesk, so there are no updates or fixes that will make it run on the latest operating system. Do you have Autocad set up to run in compatibility mode for Windows XP? If not, you should try that first. If that doesn't work, you might want to take a look at this thread at the Autodesk Discussion Groups: http://discussion.autodesk.com/forum...49755&tstart=0
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I don't understand why people would expect a program that is 10 years old to run under Windows 7 without any problems. What were you thinking?
    Forum Newbie
    Searcher1024's Computer Details
    Windows 10 Pro
    ASUS M5A99FX
    AMD FX-6350
    8 gb
    NVIDIA GeForce GTX 1050 2 gb
    Hitachi 2 Tb
    ASUS 32 inch
    Architectural
    Searcher1024's Discipline Details
    Architect
    Architectural
    Sketch-Up 2017
    Nov 2012
    6
    Actually, I just installed ACAD LT 2000 on my Windows 7 Ultimate 64-bit. The solution is so incredibly simple!!! The ReactOS website has an excellent explanation under the heading: INSTALLING 32-BIT PROGRAMS WITH 16-BIT SETUP LAUNCHER STUBS.
    See: http://www.reactos.org/forum/viewtopic.php?f=22&t=10988
    It explains that 16-bit loader stubs initiate 32-bit install programs. Older versions of AutoCAD are 32-bit programs and will run in Windows 7 64-bit OSs, but they used 16-bit installer stubs. Based on the information provided at the above referenced webpage, it is possible to identify the installer program for many AutoCAD versions as being an InstallShield installer. A 32-bit version of the installer is available here:
    Version 3 launcher replacement:
    http://toastytech.com/files/Is3Engine.zip
    Version 5 launcher replacement:
    http://toastytech.com/files/Is5Launcher.zip
    (The version of launcher you have can be found by right-clicking on SETUP.EXE and clicking on the "Version" tab.)
    You must copy your entire installation disk to a writeable directory or flash drive, and include the 32-bit setup in the same directory. In Properties, set compatibility to Windows NT 4. Run the setup32.exe program.
    For me the programs installed without any problem. It worked for me on ACLT 95 and ACLT 2000. (ACLT 2000 was an upgrade and I had to install 95 first.) Hope it works for you.
    Any program I pay $4000 for better work 10 years later!!!
  5. #5
    Forum Newbie
    Architecture 2000
    Jan 2013
    1
    Smile ACAD2000 with Windows 7
    Quote Originally Posted by Searcher1024 View Post
    [snip]
    Searcher1024, bless you! Ever since we upgraded workstations at the office a few months ago I've been suffering through the "XP Mode" solution of running ACAD2000 in a virtual machine, which has file storage issues, graphics bugaboos, and configuration headaches. I just upgraded my computer at home with Windows 7 Professional 64 -bit, and idly wondered if anyone had figured out another way to do this...and lo and behold you figured it out. Thank you very much!
    Details of my install process:
    In my case, my AutoCAD Architectural Desktop 2 CD had the version 3 installer. I copied the whole CD to the hard drive, copied the new .exe overwriting the original setup.exe, and ran the new setup.exe (using Windows 2000 compatibility to run the install).
    While installing it gave me a minor error relating to dao3032.dll and dao350.dll, but they appear to have been installed so I'm not sure what the error was. It also was unable to create a Start Menu program group so I'll have to do that manually. Lastly, I went to run the program and it said the ac1st15.dll file was missing...but it was in the "AutoCAD Shared" folder where it was supposed to be. I copied the entire contents of that folder into the main AutoCAD folder...and voila! It runs perfectly! If any issues crop up once I start really using it, I'll come back and note them in another post.
  6. #6
    Forum Newbie
    AutoCAD 2000
    Jun 2013
    1
    Default Issues
    I tried this with installer version 3. Have the disc copied to a folder with the 32 bit installer in that folder. Set compatability to NT 4 and run as admin After allowing UAC nothing happens. No install. Any advise? Steve
  7. #7
    KArthur1
    Searcher1024,
    I have acad 2000 and Win 7x64. Here is what I did.
    1. Copied the entire CD to my hard drive.
    2. Verified the verison of the installer is Installshield 3.0.111.0
    3. Downloaded and extracted the IS3Engine. Placed this Setup.exe in my folder that I just copied off the CD. Overwrote the original Setup.exe
    4. In the properties of the new Setup.exe, I change the compatibility to Windows NT 4.0 and then ran the file.
    .............. After about 20 minutes, it finally launched !!!!!
    Thanks
    I could not figure out how to get the service packs to install. The setup file for them is named "SetupEX.exe". They are not the same installer as the one for the main program. Guess I can do without the SP's.
  8. #8
    Forum Newbie
    Windows 10 Pro
    ASUS M5A99FX
    AMD FX-6350
    8 gb
    Hitachi 2 Tb
    ASUS 32 inch
    Architectural
    Architect
    Architectural
    Sketch-Up 2017
    Nov 2012
    6
    The extracted program should be setup32.exe and not setup.exe. You do not have to overwrite the original setup.exe since that is not the file you will be running. Since I do not have any service packs for ACLT2000, I am afraid that I am not able to help you in that regard. I am glad to hear that it finally launched! Sorry not to have responded sooner, but today is the first time I checked the forum in a while.
    Quote Originally Posted by KArthur1 View Post
    Searcher1024,
    Thanks
  9. #9
    Forum Newbie
    not specified
    Apr 2006
    8
    Thank you so much for this, I've been trying to figure out how to get around the installer for months now!
    I managed to get this to work for ACADLT2000; couldn't find a "version" information in setup.exe. but used is3engine.zip and it worked fine. It didn't install in my programs folder, rather I have to run the aclt.exe version that was created in the same directory the installation CD was copied on. Everything seems to work great except I can't get _pagesetup to run (and further, I can't plot) regardless of whether I try to run aclt.exe in compatibility mode for Windows XP. Luckily I'm working with years worth of files with predrawn layouts, so I've been able to get away with doing all my printing from Trueview.
    Did anyone else who tried this run into a similar problem with their install?
    Edit: Actually, I found out that if you copy the CD files to a folder directly on your C:\ drive, and direct the installer to put the program in that same folder, plotting works. I originally had it installed as a subfolder in my user folder. Had to uninstall by deleting the original files, and doing a system restore to the day before I installed everything; the uninstaller doesn't seem to work with this hack. Now I just need to find out why I get a fatal error regarding ACISMOBJ15.DBX whenever I bring up the properties box.
    Small price to pay to have CAD working again!
  10. #10
    Full Member
    AutoCAD 2000
    Jan 2009
    92
    Has anyone tried running AutoCad 2000 using DOSbox?
  1. Windows 7 64 bit & Acad 2010
    By daveyboyd in forum Software & Licensing
    Last Post: 19th Jan 2010, 06:36 am
  2. lofting in acad 2000
    By wdj in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Apr 2009, 04:18 pm
  3. ACAD 2000 + BJC-5500
    By towball in forum AutoCAD Drawing Management & Output
    Last Post: 2nd May 2006, 09:08 pm
  4. can't load autocad 2000 on windows xp home
    By karakara in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2005, 02:49 pm
