Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 29
  1. #11
    Forum Newbie
    AutoCAD 2000
    Feb 2014
    1
    Quote Originally Posted by Searcher1024 View Post
    Actually, I just installed ACAD LT 2000 on my Windows 7 Ultimate 64-bit. The solution is so incredibly simple!!! The ReactOS website has an excellent explanation under the heading: INSTALLING 32-BIT PROGRAMS WITH 16-BIT SETUP LAUNCHER STUBS.
    See: http://www.reactos.org/forum/viewtopic.php?f=22&t=10988
    It explains that 16-bit loader stubs initiate 32-bit install programs. Older versions of AutoCAD are 32-bit programs and will run in Windows 7 64-bit OSs, but they used 16-bit installer stubs. Based on the information provided at the above referenced webpage, it is possible to identify the installer program for many AutoCAD versions as being an InstallShield installer. A 32-bit version of the installer is available here:
    Version 3 launcher replacement:
    http://toastytech.com/files/Is3Engine.zip
    Version 5 launcher replacement:
    http://toastytech.com/files/Is5Launcher.zip
    (The version of launcher you have can be found by right-clicking on SETUP.EXE and clicking on the "Version" tab.)
    You must copy your entire installation disk to a writeable directory or flash drive, and include the 32-bit setup in the same directory. In Properties, set compatibility to Windows NT 4. Run the setup32.exe program.
    For me the programs installed without any problem. It worked for me on ACLT 95 and ACLT 2000. (ACLT 2000 was an upgrade and I had to install 95 first.) Hope it works for you.
    Any program I pay $4000 for better work 10 years later!!!
    I utilized this installer engine, and was able to get accept the EULA, offer authentication, define the destination, etc, but as soon as installation actually begins, I get "Error: -2 file:<drive>\<path>\DATA\A.1" where\DATA appears to be a directory created by the installer. Suggestions?
  2. #12
    Forum Newbie
    AutoCAD 2000
    Feb 2014
    3
    I try to run autocad 2000 with with W7x64 following instructions from Searcher1024,
    1. Copied the entire CD to my hard drive.
    2. Verified the verison of the installer is Installshield 3.0.111.0
    3. Downloaded and extracted the IS3Engine. Placed this Setup.exe in my folder that I just copied off the CD. Overwrote the original Setup.exe
    4. In the properties of the new Setup.exe, I change the compatibility to Windows NT 4.0 and then ran the file.
    Looks like is not working !!!!
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Yeah, well sometimes that happens. Not everyone is going to be successful.
    Let me ask....do you do any 3D drawings? Do you make use of any Express Tools commands or custom lisp routines?
  4. #14
    Forum Newbie
    AutoCAD 2000
    Feb 2014
    3
    Default acad2000 with W7x64
    I don't do any 3D drawings and do not make any Express Tools commands or custom lisp routines.
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Since that is the case then you are in luck.
    Put AutoCAD 2000 aside and forget about it. Go to the Dassault Systemes website, makers of Solidworks, and download their FREE 2D AutoCAD-clone called Draftsight. Draftsight is available in both 32-bit and 64-bit versions so make sure you download the correct one. While you are there also download the FREE Getting Started manual which is a PDF. Now DS is NOT an exact duplicate of AutoCAD but it is close enough that you should have no trouble getting used to it. DS has its own online support forum populated by other DS users so you will have a readily accessible community of people who can answer any questions you may have. DS will open any AutoCAD drawing done up to and including AutoCAD 2010 file format. It also writes to the AutoCAD 2010 file format so you can share your drawings with others. Did I mention that Draftsight and the Getting Started Guide are FREE?
  6. #16
    Forum Newbie
    AutoCAD 2000
    Feb 2014
    3
    Default autocad 2000 with W7x64 IS NO WORKING
    FREE 2D AutoCAD-clone called Draftsight is working now...thanks...
    One more problem....I cannot save dwg files as pdf files using this program.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    You can't always get what you want.
    I'm not a big fan of PDFs so it never occurred to me to look for that functionality. I don't use it so I didn't miss yet. Sorry about that.
  8. #18
    Forum Newbie
    AutoCAD 2000
    Apr 2014
    1
    Hi, I did all steps indicated, run the setup32.exe program OK, launched AutoCAD installer OK, but then appears a message ¨Can´t create folder AutoCAD 2000¨, and failed the rest of installation.
    There is nothing about Autocad installed in the Program Folder (x86).
    How can I do to solve this?
    sorry by my poor English.
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    One option would be to use a program called Longbow Converter.
  10. #20
    Forum Newbie
    Searcher1024's Computer Details
    Windows 10 Pro
    ASUS M5A99FX
    AMD FX-6350
    8 gb
    NVIDIA GeForce GTX 1050 2 gb
    Hitachi 2 Tb
    ASUS 32 inch
    Architectural
    Searcher1024's Discipline Details
    Architect
    Architectural
    Sketch-Up 2017
    Nov 2012
    6
    Are you running the program setup32.exe as Administrator? Also, the suggestion regarding DraftSight is a good one.
    A printer driver like BullZip can allow you to print a drawing file to PDFs from AutoCAD as if you were plotting it. I use it. Just FYI, I have my AutoCAD LT installed on Windows 7 64-bit Ultimate, and it all works fine for me. But of course, computers have always liked me.
  1. Windows 7 64 bit & Acad 2010
    By daveyboyd in forum Software & Licensing
    Last Post: 19th Jan 2010, 06:36 am
  2. lofting in acad 2000
    By wdj in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Apr 2009, 04:18 pm
  3. ACAD 2000 + BJC-5500
    By towball in forum AutoCAD Drawing Management & Output
    Last Post: 2nd May 2006, 09:08 pm
  4. can't load autocad 2000 on windows xp home
    By karakara in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2005, 02:49 pm
