Hi everyone just joined not too long ago, i was hoping that you will be able to help me with a problem that i'm having here at work with autocad 2004. When i put an image file into a drawing it looks fine and then when i go to plot the drawing on 30x42 paper or any paper size for that matter the image shifts to the left from the original desired position, but the "image frame" stays in the same spot.. does anyone know why my images are moving to the side and messing the whole drawing up? thanks for your help in advance..and i've already tried to re-install autocad and reinstall the plotter driver, and that didnt work... maybe i have some setting that is wrong that i dont know about? plz help
Maybe your plotter needs a Driver update? You can usually find one at the manufactures web site.
AutoCAD Civil 3D 2011
