Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2006
    Jan 2010
    6
    Default Drawing file not valid
    Hi
    Had been working on dwg, in autocad 06.
    When I go to open it, it says drawing file is not valid.
    It comes up in preview window but won't open,
    any ideas.
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,237
    Try opening it using the RECOVER command.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Forum Newbie
    AutoCAD 2006
    Jan 2010
    6
    Default drawing file not valid
    Can' open it with recover command.
    Varible settings ok
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    If you have a back up file you can rename it, make sure you use the .dwg file extension, then open up the renamed back up file. It will not have new info added after the automatic save.
  5. #5
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,237
    Is it possible that someone else opened this file with a newer version and saved in 2007 format?
    Facebook:
  6. #6
    Forum Newbie
    AutoCAD 2006
    Jan 2010
    6
    I was able to use back up file but lost some work.
    The problem occured when I closed down the dwg & couldn't save the changes.
    It went to read only.
    It wasn't a read only dwg, & wasn't set as read only in properties.
    This has occured in past with other dwgs.
    thanks
  7. #7
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by Alan View Post
    thanks
    I've seen that happen if there's a hang-up with the server. Do you work directly off one?
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  8. #8
    Forum Newbie
    AutoCAD 2006
    Jan 2010
    6
    Unsure, very large organisation
  9. #9
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    I posted this a few times on this forum: try to Partial Open the damaged file. Play around with those settings to see if you are lucky enough!
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  10. #10
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Quote Originally Posted by Cad64 View Post
    I used to have this occur on me several times.
    Someone over there in the building is on a whole different format, exited a half hour after saving a file as an earlier version, but ....
    Why, why, I saved it as your version, why didn't it keep?
    I can see it in the little preview window, but cannot go forward from there.
    Wm.
  1. Drawing file is not valid
    By solofusion in forum AutoCAD Drawing Management & Output
    Last Post: 31st Mar 2011, 06:37 pm
  2. 'Drawing file not valid'
    By Tiger in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 31st Oct 2009, 10:50 pm
  3. Drawing file is not valid....
    By rbeldua in forum AutoCAD General
    Last Post: 6th May 2009, 09:48 am
  4. Drawing file is not valid
    By Tin in forum AutoCAD General
    Last Post: 20th Apr 2009, 10:47 pm
  5. Drawing File is Not Valid
    By NiceGuy8618 in forum AutoCAD Beginners' Area
    Last Post: 3rd Jul 2008, 06:12 pm
