Results 1 to 3 of 3
    whel_13
    Default Hatch in isometric projection/drawing
    Hi guys! It’s me again J. In Autocad LT 2002
    Here’s the set up.
    New drawing.
    On the command line type
    DDVPOINT
    <select from X axis 315, XY plane 30> <you should be on "Absolute to WCS>
    then click OK
    from drop down. select tools
    then drafting settings
    then on the Snap and Grid click on ISometric snap
    Draw an ellipse, any radius (axis on the Y and Z axis)
    Can I apply the hatch command in this set up?
    Thanks...
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    You can hatch a plain closed boundary as long as it is placed on (or it is parallel with) the XOY plane. It is not important the direction of view. If the ellipse had one axie parallel with the OX and the other with the OZ plane it is placed on the XOZ plane. In this case rotate the UCS around the OX axe and than you can hatch.
    Please tell me: do you begin all your messages by pasting the “header” from somewhere?
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    whel_13
    yeah...
    I write my queries in ms word first then i pasted it on the message body when I'm already online.
    I'm using the same heading so that the reader could understand or follow my set up on my drawing.
    thanks...
