Nilesh Jagtap Posted March 24, 2010 Share Posted March 24, 2010 hi friends... i have one common query in civil 3d ....tht is i have two assemblies which placed in one corridor with "split region" in corridor...( see image "assembly pic" ) but how to join these two assembly having different slopes, plz see image "corridor" ...k Quote Link to comment Share on other sites More sharing options...
bobafett Posted December 20, 2010 Share Posted December 20, 2010 all of this time and no replies? Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 First of all, welcome to the forum..... Very interesting first post. Sometimes things dont get answered. We are all volunteers on this site, no one gets paid to sit here and answer questions. If you have any incite in to the issue the OP has brought up, by all means help out. Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 one more thing. Sometimes posting your questions in the "general" area will yield better results. You will notice that the general forum on the front page has the most traffic! Quote Link to comment Share on other sites More sharing options...
bobafett Posted December 21, 2010 Share Posted December 21, 2010 I meant no disrespect. I was just hoping for an answer to the OP. I am having the same issue he had. Thank you for the tip about the "general" area. Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 21, 2010 Share Posted December 21, 2010 None taken. You would be surprised at how many people come here and demand things. One guy posted a college final exam and wanted someone to do it for him!!!! Since this site is really run buy "users" its up to us to make sure things are done in a professional manner and to convey what this website is for, which is "CADTutor"ing, not "CADdomyworkforme" and what not. Also, Ive seen people ignored because of their conduct, so that is something to be aware of. Happy foruming! Quote Link to comment Share on other sites More sharing options...
Hansl Posted February 8, 2014 Share Posted February 8, 2014 Any new insights on this topic? Quote Link to comment Share on other sites More sharing options...
Organic Posted February 9, 2014 Share Posted February 9, 2014 It is hard to see from the pictures what exactly is going on although it looks like one template (assembly) has been applied then immediately (1m later say) a quite different (in cross section definition) template has been applied. The solution would be to apply the transition over a greater distance (e.g. 10m, not 1m or less as shown). If you are only producing cross sections before and after the template changes (and not in the transition region) then it doesn't matter 100% if the transition is modeled correctly or not - the difference is minimal. If more accuracy is needed along the transition then multiple templates (assemblies) could be used; each of which would be have to be defined for a different stage of the transition. These would then need to be applied at appropriate positions along the corridor (over a larger length, 10m or so, than what is shown in the first picture) Quote Link to comment Share on other sites More sharing options...
PEGAdevelopment Posted February 20, 2014 Share Posted February 20, 2014 The key is feature lines. You need to use feature lines to transition from one corridor to the next. You will have to stop the first corridor then have a transition area that is solely feature lines. This will connect to the second corridor which has a different assembly. You need to draw 3d polylines in the transition area by hand, then convert them to feature lines, then add them to the surface as breaklines. Here is an example pic where I had a boulevard section with medians, but needed to transition to an area without medians. The orange lines are feature lines that have been added to the surface as breaklines. Quote Link to comment Share on other sites More sharing options...
JerryG Posted March 3, 2014 Share Posted March 3, 2014 Very nice work around Pega. I am working on an area where a two lane road with a 5' wide ditch with no flat bottom transitions into a 3 lane road with 6' ditches with a flat bottom. Even though I had created quites a few intermediate assemblys like what Organic was suggesting it did not have the nice smooth transitions I was looking for due to the flat portion of the ditch. I think I'll retry it using feater / breaklines. Thanks for posting! Quote Link to comment Share on other sites More sharing options...
mariawndas Posted September 29, 2016 Share Posted September 29, 2016 Hello, I'm a newbie here. Nice posting Pega. I have a same problem here (a boulevard section with medians, but needed to transition to an area without medians, just like your example pic). Would you tell me step by step how to use feature lines to transition from one corridor to the next? Thank you Quote Link to comment Share on other sites More sharing options...
