Results 1 to 7 of 7
    Senior Member iskalipsi's Avatar
    Architectural
    iskalipsi's Discipline Details
    designer
    Architectural
    Office planning. Furniture design. Minor estimate of civil works.
    AutoCAD 2009
    Sep 2009
    Philippines
    237
    Default Sun color wont change
    I was practicing rendering with the materials from tool palettes today, my problem is i cant change the sun's color. It seems to be locked in 0,0,0 color. What tweaking should i do? Thanks
    Don't work too hard. Nobody notices anyway.
    Senior Member arjun_samar's Avatar
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    hope it helps
    Architectural
    designer
    Architectural
    AutoCAD 2009
    Sep 2009
    Philippines
    237
    Thanks for your reply arjun. I tried to change the time but still its locked to 0,0,0 color.This is my first time to encounter this problem. I can't seem to figure what to do.
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    try to open a new file and do it again, if the problem still persist let me know
  5. #5
    Architectural
    designer
    Architectural
    AutoCAD 2009
    Sep 2009
    Philippines
    237
    I copied my model into a new sheet but still the same.
  6. #6
    Senior Member Fire Alarm's Avatar
    Fire Alarm's Computer Details
    Windows Vista
    Dell XPS XPS710
    MEP 2008
    May 2008
    Wilmington, DE
    111
    You have to change the lightingunits (type into the command line) from 1 to 0. Then you can change the color.
    There is no limit to what one can do with knowledge and imagination.
  7. #7
    Architectural
    designer
    Architectural
    AutoCAD 2009
    Sep 2009
    Philippines
    237
    Thanks for the reply. but i have figured this already.This thread was 2 years ago.
  1. Trying to change the Color of the sky
    By Bowl.Spliffson in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Oct 2010, 10:31 am
  2. add/change color
    By katto01 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Mar 2010, 09:23 pm
  3. Lisp to change all objects with a certain color to another color
    By mikeSIEMENS in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2010, 04:59 pm
  4. When I change the color the dimensions change!
    By Mark Costantino in forum AutoCAD Drawing Management & Output
    Last Post: 12th Oct 2009, 05:55 pm
  5. Layer wont change when selecting object
    By VBoss in forum AutoCAD General
    Last Post: 16th May 2009, 03:09 pm
