gsksun4 Posted March 25, 2010 Share Posted March 25, 2010 Trying to draw a simple tube on a 30 degree angle and can't get the ellipse right. Last time I did this was on the board with 30 a degree triangle and a 30 degree ellipse template. I'm in isolplane and ortho, and toggling with F5, but it just doesn't look right. Using 2009LT. Is there a simple fix? Glenn USA ISO-DWG.dwg Quote Link to comment Share on other sites More sharing options...
profcad Posted March 25, 2010 Share Posted March 25, 2010 Change your snap to isometric snap (DSETTINGS). Once you change your snap, then the ISOCIRCLE option will be available on the ellipse command. Use CTRL-E to switch between TOP, LEFT, and RIGHT view. Quote Link to comment Share on other sites More sharing options...
gsksun4 Posted March 25, 2010 Author Share Posted March 25, 2010 Change your snap to isometric snap (DSETTINGS).Once you change your snap, then the ISOCIRCLE option will be available on the ellipse command. Use CTRL-E to switch between TOP, LEFT, and RIGHT view. Ah. Isocircle. Forgot all about that. Attached is the good and the bad, Thank you very much. ISO-DWG.dwg ISO-DWG2.dwg Quote Link to comment Share on other sites More sharing options...
