Results 1 to 5 of 5
    Junior Member
    AutoCAD 2009
    Feb 2009
    11
    Default Why Is My Drawing Turning White?
    This problem has started happening recently for whatever reason, but when I save my drawing (doesnt happen always), but it will turn everything on my drawning white in paper space.
    The layers are fine and the colors are fine, the properties are not changing. However the drawing being viewed is all white. When I look at my objects in the model space tab it is normal (all lines represent the correct color)
    Does anyone have an explanation and a way that I can fix this?
    Thanks
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Life's constantly changing - keep up or get left behind
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Display Plot Styles F1
    Turn it off.
    Junior Member
    AutoCAD 2009
    Feb 2009
    11
    Awesome, yeah that fixed it thanks guys.
    So why is it checking that box off for me in the first place? Been using 2009 for a year and it hasnt started to do it until now. Its an everyday thing. I dont want to have to check off a box all the time cause it converts it to white.
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    My first guess is to check the Template you are using.
  1. White or Black Drawing Window?
    By viriato79 in forum AutoCAD General
    Last Post: 2nd Nov 2009, 09:40 pm
  2. Drawing information in layout tab is white but coloured in Model
    By mxpxh2o in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th May 2009, 03:01 pm
  3. turning CAD drawing to PDF..
    By JessicaDeaken in forum AutoCAD Beginners' Area
    Last Post: 21st Jan 2008, 05:40 pm
  4. Properties box turning white and blank
    By GSE in forum AutoCAD Drawing Management & Output
    Last Post: 13th Nov 2007, 05:49 am
  5. turning 2d into 3d drawing
    By civil eng in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Mar 2006, 06:53 am
