Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2010
    Mar 2010
    Ontario Canada
    6
    Question "Hover-over" Information Pop-up
    Hi, this is my first post here. I am in dire need of some help. My boss has asked me to figure out how to hover my cursor over top of an image created in AutoCAD, (ex. Door, machine, pipe, etc.) and get a little pop-up with information on it to appear
    (Ex. hovering cursor over a pipe, "4' Commercial Pipe, El. 1095'-0", top of pipe, Serial #", etc would pop-up)
    I have been playing around with hyperlinks, and rollover tooltips, but can't seem to figure out how to get the information to immediately pop-up when scrolled over.
    (Using 2010)
    Any help would be great!!!!
    THANK YOU!!
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    I think the "Pipe" has to be an "Object" like a line, arc, circle, Block, etc. that is defined in AutoCAD.
    I use generic AutoCAD LT 2009 and my hover only displays the object group name, color, layer and object sub-type. As far as I can tell, there is no way to vary the data displayed in the box. It is merely basic AutoCAD Properties.
    I am not sure what sort of objects you can have defined in the verious industry specific versions of AutoCAD. If yours already has a "palette'o'Pipes", or lets you create "Pipe Types" then it should already work. In other words, AutoCAD does not know a collection of lines adds up to a particular object unless it is told.
    Possibly this would require creating your pipe types as blocks and use the pertinant data as the block name.
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    Do you need this information to be displayed inside of AutoCAD? Or just maybe an image of your .DWG file.
    If so, you can use JPGOUT to create the image then create an image map to be displyed in a web browser which will give you a lot of options such as hover and linking to other files.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    Forum Newbie
    AutoCAD 2010
    Mar 2010
    Ontario Canada
    6
    Thanks for your reply!
    Yes, my drawing just consists of separate lines, my pipes are not blocks, but I will try making them blocks, and naming them with the information I need displayed. I was hoping there was another way to use a hyperlink or something, so when I scroll over it, data I have inputted shows up, but I will try this.
    THANKS!
  5. #5
    Forum Newbie
    AutoCAD 2010
    Mar 2010
    Ontario Canada
    6
    kencaz,
    Yes, my boss wants it to display directly in Autocad. Otherwise I would have just created a hyperlink and had an excel file open i think, but he wants to just scroll over it and have it pop up. This is just my second month of using autocad, so I am still learning a lot. I will play around with JPGOUT though, and see what it does.
    Thanks!!
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by Sam_CAD_Learner View Post
    kencaz,
    Thanks!!
    Yeah, well.... I had a boss once who wanted me to draw strechable kitchen cabinets as blocks to save time. His AutoCAD release was two years prior to Dynamic blocks being available, so of course I could not do it. He had seen AutoCAD 2007 and 2020 Design at a kitchen cabinet trade show and didn't know the stretchy stuff was a new thing. I eventually built a library of dynamic cabinet blocks, but for a new employer. That was not the reason for changing work places, although he was.
  7. #7
    Forum Newbie
    AutoCAD 2010
    Mar 2010
    Ontario Canada
    6
    Wow! Well, I luckily have a great boss, he is very reasonable. Being a student and all I was hoping to impress him when he asked for this thismorning lol
    Making them into blocks and naming them is working btw, the only thing I can't do is edit the name after I created it, which is on the annoying side lol.
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Yeah, that is a bummer, but you can open the prior block def and save it as the next one after making changes for the new one.
  9. #9
    Forum Newbie
    AutoCAD 2010
    Mar 2010
    Ontario Canada
    6
    Smile
    Yes I noticed that, that's nice for sure.
    Thanks for your help! I think he will be pleased!!
    CHEERS
  10. #10
    Full Member
    dshowalt's Computer Details
    Windows 7 64-bit
    Intel i7
    8GB
    Nvidia
    Education
    dshowalt's Discipline Details
    Education
    Education
    Inventor 2012
    Dec 2009
    Kansas City, USA
    57
    So with the various arcs, lines, etc converted to blocks and the block named with the specification you want, when you pick it in the drawing the Quick Properties will tell you what ou want. It's not hover but pretty close
    Better yet, Name the block something descriptive.And then assign attributes to the block to spec the actual details. Now you can edit the quick Properties to display the Name and the Attributes, and still do an attribute extraction on the drawing for BOM purposes. two for one. the boss should like that
  1. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  2. "move" order works as "copy"
    By DinaMaaty in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 15th Feb 2013, 01:13 pm
  3. saving as "step" and/or "inventor" file
    By jmatus86 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th May 2011, 01:56 pm
  4. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
  5. "incorrect or corrupted information"
    By Rudbeckia in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Feb 2008, 05:49 am
