Results 1 to 3 of 3
    Forum Newbie
    not specified
    Nov 2005
    Las Vegas
    4
    Default LISP to select by color
    I'm trying to make a LISP that cleans up a drawing. When I import the drawing everything is on the same layer, just different colors. I need to delete certain colors. I'm not sure how to do selection by color other than quick select, and that needs manual input, which I'm trying to avoid.
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,925
    This snippet would erase all entities colored 2 6 121 & 250
    AS IS
    Code:
      (foreach c '(2 6 121 250)
        (and (setq ss (ssget "X" (list (cons 62 c))))
             (command "_.ERASE" ss "")))
    That could be a bit dangerous. Good Luck
    Opps - Missed the "X" first time. -David
    R12 (Dos) - A2K
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    801
    Here is one way.
    Code:
    ;;     cSel.lsp by Charles Alan Butler
    ;;            Copyright 2005
    ;;   by Precision Drafting & Design All Rights Reserved.
    ;;        Contact at ab2draft@TampaBay.rr.com
    ;;    Version 1.0 Beta  July 13,2005
    ;;          C o l o r   S e l e c t
    ;;   Creates a selection set of objects of a color
    ;;   Objects with color ByLayer are selected by color also
    ;;   User picks objects to determine the color
    ;;   Then User selects objects for ss or presses enter to
    ;;   get all objects on the selected color
    ;;   You may select the selection set before starting this
    ;;   routine. Then select the layers to keep in the set
    (defun c:csel (/ ent col colors layers ss col:lst col:prompt ss:first
                   elst filter lay:lst x ent:lst get_layer get_color_name)
      (vl-load-com)
      ;;  return a list of layers using the colors in the list
      ;;  col:lst is a list of color numbers
      (defun get_layer (col:lst / lay lays doc)
        (setq doc (vla-get-activedocument (vlax-get-acad-object)))
        (vlax-for lay (vla-get-layers doc)
          (if (and (member (vla-get-color lay) col:lst)
                   (not (vl-string-search "|" (vla-get-name lay)))
            (setq lays (cons (vla-get-name lay) lays))
        lays
      ;; return the color name from the color number supplied
      ;; else return the number as a string
      (defun get_color_name (c# / col)
        (setq col (assoc c# '((1  "Red")
                              (2  "Yellow")
                              (3  "Green")
                              (4  "Cyan")
                              (5  "Blue")
                              (6  "Magenta")
                              (7  "Black/White")
                              (8  "Dark Grey")
                              (9  "Grey"))
        (or (cadr col) (itoa c#))
      ;;                       Main Routine
      ;;  get anything already selected
      (setq ss:first (cadr(ssgetfirst))
            ss (ssadd))
      ;;  Get user selected colors
      (if ss:first
        (setq col:prompt "\nSelect the object to choose color to use.")
        (setq col:prompt "\nSelect object for color filter.")
      (while (setq ent (entsel col:prompt))
        (redraw (car ent) 3) ; highlite the object
        (setq ent:lst (cons (car ent) ent:lst))
        (setq col (cdr(assoc 62 (entget (car ent))))); get the color
        (if (null col) ; color is ByLayer, get layer color
          (setq col (cdr (assoc 62
                                (tblsearch "layer"
                                         (cdr (assoc 8 (entget (car ent))))))))
        (setq col:lst (cons col col:lst))
        (prompt (strcat "\n*-* Selected Color # -> " (get_color_name col)))
      ;;  Un HighLite the entities
      (and ent:lst (mapcar '(lambda (x) (redraw x 4)) ent:lst))
      (if (> (length col:lst) 0); got color to work with
          &#40;setq col&#58;lst &#40;vl-sort col&#58;lst '<&#41;&#41; ; removes douplicates
          &#40;setq colors "" layers ""&#41;
          &#40;setq lay&#58;lst &#40;get_layer col&#58;lst&#41;&#41; ; get layers using the colors
          &#40;foreach itm  col&#58;lst ; combine color names into one , del string
            &#40;setq colors &#40;strcat colors &#40;itoa itm&#41; ","&#41;&#41;&#41;
          &#40;setq colors &#40;substr colors 1 &#40;1- &#40;strlen colors&#41;&#41;&#41;&#41;; remove the last ,
          &#40;foreach itm  lay&#58;lst ; combine layer names into one , del string
            &#40;setq layers &#40;strcat layers itm ","&#41;&#41;&#41;
          &#40;setq layers &#40;substr layers 1 &#40;1- &#40;strlen layers&#41;&#41;&#41;&#41;; remove the last ,
          &#40;if ss&#58;first ; ALREADY GOT SELECTION SET
            &#40;while &#40;setq ent &#40;ssname ss&#58;first 0&#41;&#41;
              &#40;setq elst &#40;entget ent&#41;&#41;
              &#40;if &#40;or &#40;and &#40;assoc 62 elst&#41; ; got a color
                           &#40;member &#40;abs &#40;cdr&#40;assoc 62 elst&#41;&#41;&#41; col&#58;lst&#41;&#41; ; color match
                      &#40;and layers
                           &#40;member &#40;cdr&#40;assoc 8 elst&#41;&#41; lay&#58;lst&#41;
                           &#40;or &#40;null &#40;assoc 62 elst&#41;&#41;
                             &#40;= &#40;cdr&#40;assoc 62 elst&#41;&#41; 256&#41;&#41;&#41;  ; bylayer
                      &#41;
                &#40;ssadd &#40;ssname ss&#58;first 0&#41; ss&#41;
              &#41;
              &#40;ssdel &#40;ssname ss&#58;first 0&#41; ss&#58;first&#41;
            &#41;
            ;; else get a selection set to work with
            &#40;progn
              &#40;prompt &#40;strcat "\nOK >>--> Select objects for Selection set or "
                              "ENTER for All objects on color&#40;s&#41; " colors&#41;&#41;
              ;;  create the filter
              &#40;if layers
                &#40;setq filter &#40;append
                               &#40;cons '&#40;-4 . "<OR"&#41; &#40;mapcar '&#40;lambda &#40;x&#41; &#40;cons 62 x&#41;&#41; col&#58;lst&#41;&#41;
                               &#40;list '&#40;-4 . "<AND"&#41;
                                     &#40;cons 8 layers&#41;
                                     '&#40;62 . 256&#41; ;  ByLayer
                                     '&#40;-4 . "AND>"&#41;
                                     '&#40;-4 . "OR>"&#41;
                                    &#41;&#41;&#41;
                &#40;setq filter &#40;list &#40;cons 62 colors&#41;&#41;&#41;
              &#41;
              ;;  get objects using filter with user select
              &#40;if &#40;null &#40;setq ss &#40;ssget filter&#41;&#41;&#41;
                ;; or get ALL objects using filter
                &#40;setq ss &#40;ssget "_X" filter&#41;&#41;
              &#41;
            &#41;
          &#41;
          &#40;if &#40;> &#40;sslength ss&#41; 0&#41;
            &#40;progn
              &#40;prompt &#40;strcat "\n" &#40;itoa &#40;sslength ss&#41;&#41;
                          " Object&#40;s&#41; selected on color&#40;s&#41; " colors
                          "\nStart an ACAD command."&#41;&#41;
              &#40;sssetfirst nil ss&#41;
            &#41;
            &#40;prompt "\n***  Nothing Selected  ***"&#41;
          &#41;
        &#41;
      &#41;
      &#40;princ&#41;
    &#41;
    &#40;prompt "\nSelect by color loaded, Enter cSel to run."&#41;
