Results 1 to 6 of 6
    Junior Member
    AutoCAD 2008
    Oct 2009
    24
    Default cut line to desired length
    Hellow, i work with alot of angled lines and i was wondering is there a way to cut a line to a desired length from a point???
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,785
    Draw a circle and trim
    Else there may be a lisp program search here
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,000
    Did you try Lengthen?
    DropBox | finding the light...
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
    Junior Member
    AutoCAD 2008
    Oct 2009
    24
    lengthen looks promising what does delta and dynamic do?
  5. #5
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    I've found you can learn a lot by diving in and experimenting.
    If the prompts and results are confusing, I've been known to hit the F1 key.
  6. #6
    Civil 3D 2011
    Apr 2008
    6,000
    Quote Originally Posted by luke83 View Post
    Try them and find out.
  1. Line length
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 24th Oct 2009, 12:23 am
  2. line length sum ?
    By fuqua in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jul 2009, 01:12 pm
  3. LINE LENGTH
    By goody in forum AutoCAD Beginners' Area
    Last Post: 1st Jul 2006, 10:34 am
  4. Problem with specifying line length
    By Tara in forum AutoCAD Drawing Management & Output
    Last Post: 9th Mar 2004, 01:24 pm
  5. Line Length
    By CherylC in forum AutoCAD Beginners' Area
    Last Post: 30th Mar 2003, 11:54 pm
