Draw a circle and trim
Else there may be a lisp program search here
Hellow, i work with alot of angled lines and i was wondering is there a way to cut a line to a desired length from a point???
Did you try Lengthen?
DropBox | finding the light...
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
lengthen looks promising what does delta and dynamic do?
I've found you can learn a lot by diving in and experimenting.
If the prompts and results are confusing, I've been known to hit the F1 key.![]()
