Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Junior Member
    AutoCAD 2009
    Apr 2009
    13
    Default How do I display an empty/blank dimension value?
    I remember doing this a few years ago, but forget the text formatting control codes. When clicking on a dimension than checking the Properties palette, I go down to the Text Override box and put in some kind of code to display a blank/empty value. It looked something like this < \>. Does anyone remember how to do that? Maybe I have the symbols in the wrong order or need a letter after the backslash. I know <> returns the actual dimension value, but what combination of letters symbols hides the value, so it can't be seen in the drawing? Basically what would be seen is a dimension without any text or numbers.
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    ALT+255 in Text override will display nothing but still have a gap where the dim should be.
    KC
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    Junior Member
    AutoCAD 2009
    Apr 2009
    13
    Quote Originally Posted by kencaz View Post
    KC
    Ok, KC, I'll try that tomorrow. Maybe I can get rid of the gap if I adjust the properties to move where the supposed text would be to another area of the dimension. Anyone else know what I'm searching for?
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Try just putting a single space " ".
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  5. #5
    Junior Member
    AutoCAD 2009
    Apr 2009
    13
    Quote Originally Posted by alanjt View Post
    Alright, Alan, I'll try that too. If I figure it out, I'll be sure to post it tomorrow. Good night.
  6. #6
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    KC
    I'm going to try just as soon as I can. Oops! Just worked between try 'n just. Nice!
    I see a simple tap on the spacebar worked too. Fast 'n easy!
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  7. #7
    HP,s Dell
    Mechanical
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    LOL, I had to go and make it all complicated...
    KC
  8. #8
    Junior Member
    AutoCAD 2009
    Apr 2009
    13
    @Alan: Yep, a simple space suffices! Thanks all for sharing.
  9. #9
    Civil 3D 2013
    Apr 2008
    6,199
    KC
    No worries. I do that same thing all the time.
    Quote Originally Posted by dughug View Post
    Good deal. Here's a little code to make life even easier...
    Code:
    (defun c:DimBlank (/ ss e)
      (vl-load-com)
      (and (setq ss (ssget "_:L" '((0 . "DIMENSION"))))
           ((lambda (i)
              (while (setq e (ssname ss (setq i (1+ i))))
                (vl-catch-all-apply
                  (function vla-put-textoverride)
                  (list (vlax-ename->vla-object e) " ")
                ) ;_ vl-catch-all-apply
              ) ;_ while
            ) ;_ lambda
             -1
      ) ;_ and
    ) ;_ defun
    DropBox
  10. #10
    Junior Member
    AutoCAD 2009
    Apr 2009
    13
    Code:
      (vl-load-com)
           ((lambda (i)
                (vl-catch-all-apply
              ) ;_ while
            ) ;_ lambda
             -1
      ) ;_ and
    ) ;_ defun
    Alan, what does this code do?
  1. deleting empty layers
    By reyems in forum AutoCAD Beginners' Area
    Last Post: 9th Jan 2010, 11:40 pm
  2. Drawing seems empty (although is not)
    By Organic in forum AutoCAD Beginners' Area
    Last Post: 20th Mar 2009, 04:04 pm
  3. dimension style couldn't display properly.
    By ANEV in forum AutoCAD Beginners' Area
    Last Post: 5th Nov 2008, 05:25 pm
  4. Dimension display question.
    By RingSteel in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Apr 2008, 12:47 am
