Refer to a dynamic block visibility state VBA
kyosmith
How to refer a dynamic block visility state with VBA?
in some cases i need to insert a block with a diferent visibilty state. and i dont want to create diferent blocks for each visibility state.
is it possible to do that?
thanks all!
It is possible although I only investigated doing it rather than using it. However, your profile says you are using LT - you won't have access to VBA or LISP. Is your profile wrong?
Maybe you should change your profile :)
Its taken me a little while to find what I did but here is a code extract.
Public Sub SelSetTest1()
Dim BlockRefObj As AcadBlockReference
Dim PropList As Variant
Set BlockRefObj = mySelectionSet.Item(0)
PropList = BlockRefObj.GetDynamicBlockProperties
I was using a selectionset to get my object but you can use whatever works for you. Once you have the properties list you can read the visibility sate or set the visibility state.
