srikanthkamuju Posted April 2, 2010 Share Posted April 2, 2010 Hi All i am taking 2d polyline as input i want the coordinates of that polyline with bulge factor. later on how to draw a 3d poly line with that same points Thanks in advance Quote Link to comment Share on other sites More sharing options...
lpseifert Posted April 2, 2010 Share Posted April 2, 2010 I don't think 3Dpolylines can have a bulge factor, must be straight segments. Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 2, 2010 Share Posted April 2, 2010 If understand well your issue, the code below will allow you to create a list with vertexes of polyline (no error protections), next use SUBST function to modify the Z coordinate with desired amount (this code should be based on length of vertexes list) and generate the 3D polyline from this list. (setq PLineEntity (car (entsel "Select polyline: ")) ;select polyline to list PLineAssocList (entget PLineEntity) ;get his associated list VertexesList '()) (foreach SubList PLineAssocList ;parse polyline to list vertexes (if (= (car SubList) 10) ; code DXF 10 = vertex (setq VertexesList (append VertexesList ;store vertex coordinates (list (cdr SubList)))) ) ) Regards, Quote Link to comment Share on other sites More sharing options...
MSasu Posted April 2, 2010 Share Posted April 2, 2010 In fact seems that the OP is looking for a VBA solution – the same is posted in AutoCAD Beginners' Area, also… Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 2, 2010 Share Posted April 2, 2010 I don't think 3Dpolylines can have a bulge factor, must be straight segments. You could in the old-school 2d ones. Quote Link to comment Share on other sites More sharing options...
David Bethel Posted April 3, 2010 Share Posted April 3, 2010 Here is a routine in Autolsip that will convert any LINE, ARC or *POLYLINE to a 3DPOLY. -David FIXPATH.LSP Quote Link to comment Share on other sites More sharing options...
