Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 62
    Senior Member
    AutoCAD 2010
    Mar 2010
    112
    Default Erase objects outside of boundary ( polyline )
    Hi all.
    I need a routine that can erase all object inside or outside of a closed polyline or boundary (based on my selection point in or out) in aotucad drawing.
    Is there any solution?
    thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Here's a routine for easing inside a closed polyline.
    http://cadtips.cadalyst.com/polyline...a-closed-pline
    Senior Member
    AutoCAD 2010
    Mar 2010
    112
    Thanks ReMark.
    I 've tested it before. but always it show this error:
    "The POLYLINE isn't CLOSED...
    Nothing Selected...
    Select object :"
    I can't understand the reason of this error. cause i draw a closed polyluine by myself.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,460
    Here's a quick one for inside:
    Code:
    (defun c:pDel (/ GroupByNum _GetLocked lst->str ENT I LK OBJ PTLST SS)
      (vl-load-com)
      ;; Lee Mac  ~  02.04.10
      (defun GroupByNum (lst num / rtn)
        (setq rtn nil)
        (if lst
          (cons (reverse
                  (repeat num
                      (setq rtn (cons (car lst) rtn)
                            lst (cdr lst))
                      rtn)))
                (GroupByNum lst num))))
      (defun _GetLocked (/ tdef lk)
        (while (setq tdef (tblnext "LAYER" (not tdef)))
          (if (= 4 (logand 4 (cdr (assoc 70 tdef))))
            (setq lk (cons (cdr (assoc 2 tdef)) lk)))))
      (defun lst->str (lst del / str)
        (setq str (car lst))
        (while (setq lst (cdr lst)) (setq str (strcat str del (car lst))))
      str)
      (while
          (setq ent (car (entsel "\nSelect Polyline: ")))
          (cond (  (eq 'ENAME (type ent))
                   (if (wcmatch (cdr (assoc 0 (entget ent))) "*POLYLINE")
                       (setq ptLst
                         (GroupByNum
                           (vlax-get
                             (setq obj (vlax-ename->vla-object ent)) 'Coordinates)
                           (if (eq "AcDbPolyline" (vla-get-ObjectName obj)) 2 3)))
                       (if (cadr
                             (sssetfirst nil
                               (setq i -1 ss
                                 (ssget "_WP" ptLst
                                        (if (setq lk (_GetLocked))
                                          (list (cons -4 "<NOT")
                                                (cons 8 (lst->str lk ",")) (cons -4 "NOT>")))))))
                         (if (progn
                               (initget "Yes No")
                               (not (eq "No" (getkword "\nDelete Objects? [Yes/No] <Yes> : "))))
                           (while (setq ent (ssname ss (setq i (1+ i))))
                             (entdel ent))
                           (sssetfirst nil nil))
                         (princ "\n** No Objects Found **")))
                     (princ "\n** Object Must be a Polyline **"))))))
      (princ))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  5. #5
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Try this, a quicky, no error control
    it worked the few times I tried it
    Code:
    ;;; Erase in or out of polyline  LPS 2010-04-02
    (defun c:test (/ idx obj endparam cnt pnt ss1)
    (vl-load-com)
      (setq ptlst nil)
      (setq ss1 nil)
      (setq obj (vlax-ename->vla-object (car (setq pl (entsel "\nSelect polyline boundary: ")))))
      (if (or; test if polyline and has area
        (/= (vlax-get-property obj 'ObjectName) "AcDbPolyline")
        (zerop (vlax-get-property obj 'Area))
        (princ "\nSelected entity is not a polyline or can not be used for a section window")
      (setq p1 (getpoint "Pick side to erase: ")
        pnt (entmakex
            (list (cons 0 "point")
               (cons 10 p1))
      (setq ptlst (list (vlax-curve-getStartPoint obj))
        idx 1)
      (if (zerop (vlax-get obj 'Closed))
            (setq endparam (vlax-curve-getParamAtPoint obj (vlax-curve-getEndPoint obj)));if open param at end point
        (setq endparam (cdr (assoc 90 (entget (vlax-vla-object->ename obj)))));if closed # vertices
      (while
        (<= idx endparam)
          (if;test for curve -  thanks to Lee Mac and others
        (not
          (equal
                (angle '(0 0 0)
                  (vlax-curve-getSecondDeriv obj (1- idx))) 0.0 1e-8)
          );not
          (setq cnt (1- idx))
          (repeat 15;divide curve
            (setq ptlst(cons (vlax-curve-getPointAtParam obj (+ cnt 0.0625)) ptlst)
                  cnt (+ 0.0625 cnt))
            );repeat
          );progn
        );if
       (setq ptlst (cons (vlax-curve-getPointAtParam obj idx) ptlst)
         idx (1+ idx))
       );while
      (setq ptlst (reverse ptlst))
      (setq ss1  (ssget "_WP" ptlst))
      (if
        (ssmemb pnt ss1)
          (vl-cmdf "erase" ss1 "")
          (setq ss1  (ssget "_CP" ptlst))
          (vl-cmdf "erase" "all" "r" ss1 pl ""))
      );defun
  6. #6
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Tried to post earlier but my computer crashed and then my little girl woke up...
    Code:
    (defun c:EIO (/ _p2ss o ent ssIn ssOut)
      ;; Erase Inside/Outside of selected LWPolyline
      ;; Alan J. Thompson, 04.02.10
      (vl-load-com)
      (or *EIO:Opt* (setq *EIO:Opt* "Inside"))
      (setq _p2ss (lambda (ename)
                    (ssget "_WP"
                           ((lambda (e / l)
                              (foreach x e (and (eq 10 (car x)) (setq l (cons (cdr x) l))))
                              (reverse l)
                            ) ;_ lambda
                             (entget ename)
                    ) ;_ ssget
                  ) ;_ lambda
      ) ;_ setq
      (and (setq o (car (entsel "\nSelect LWPolyline: ")))
           (or (eq "LWPOLYLINE" (cdr (assoc 0 (setq ent (entget o)))))
               (alert "Invalid object!")
           ) ;_ or
           (not (initget 0 "Inside Outside"))
           (setq *EIO:Opt*
                  (cond
                    ((getkword (strcat "\nSpecify erase option [Inside/Outside] <" *EIO:Opt* ">: ")))
                    (*EIO:Opt*)
                  ) ;_ cond
           ) ;_ setq
           (cond
             ((and (eq *EIO:Opt* "Inside") (setq ssIn (_p2ss o)))
              ((lambda (i)
                 (while (setq e (ssname ssIn (setq i (1+ i))))
                   (or (eq o e) (vl-catch-all-apply (function entdel) (list e)))
                 ) ;_ while
               ) ;_ lambda
                -1
             ((eq *EIO:Opt* "Outside")
                    ssOut (ssget "_X" (list (cons 410 (getvar 'ctab))))
              ) ;_ setq
              ((lambda (i)
                 (while (setq e (ssname ssOut (setq i (1+ i))))
                   (if ssIn
                     (or (ssmemb e ssIn) (eq o e) (vl-catch-all-apply (function entdel) (list e)))
                   ) ;_ if
                 ) ;_ while
               ) ;_ lambda
                -1
           ) ;_ cond
      ) ;_ and
    ) ;_ defun
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  7. #7
    Senior Member
    AutoCAD 2010
    Aug 2009
    Baltimore, MD
    111
    I use MAPTRIM found in Autodesk Map.
  8. #8
    Senior Member
    AutoCAD 2010
    Mar 2010
    112
    I'm so thankful of Lee Mak,ipseifert and alanjt.
    After testing all codes that you posted in this thread,i reach some errors or nil action.
    By Lee 's code:
    Select Polyline:
    By ipseifert 's code:
    Pick side to erase: ; error: bad argument type:
    lselsetp nil
    By alanjt 's code:
    By type "i" for inside, nothing happens.
    By type "o" for outside, all entities erase, except lwpolyline that selected.
    please help me if i have wrong operation with my drawing.
  9. #9
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by kasra View Post
    By Lee 's code:
    Select Polyline:
    lselsetp nil
    By alanjt 's code:
    Works fine on my end. Are the objects touching the selected LWPolyline?
    Could you post an example?
    DropBox
  10. #10
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    lselsetp nil
    Did you happen to pick outside the polyline boundary that had no selectable entities inside? If that is the case you really don't need a routine.
  1. Mirroring; erase source objects? YES!
    By Sarah H in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th May 2009, 04:58 pm
  2. Mirror.. Or Erase source objects to be exact.
    By stevsmith in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Apr 2009, 12:40 pm
  3. Erase objects outside of boundary ( polyline )
    By mitchellamazing in forum AutoCAD Beginners' Area
    Last Post: 1st Dec 2008, 10:30 am
  4. Erase within an existing polyline
    By P_c in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2008, 12:50 pm
  5. Boundary polyline -> Valid Hach Boundary Not Found
    By Jauch-BR in forum AutoCAD Beginners' Area
    Last Post: 23rd Jan 2007, 02:32 pm
