what should I use to draw water?
supernoke
I am creating a pool with stairs and so on
now i have to make the water.
Does the pool be filled totally (solid)?
or can i cover my pool with a planar surface
If i make a section it would be cool if i see the water also.
I like to see the stairs and the bottom of the pool through the water.
Anyone give me few tips?
ty
supernoke :geek:
Ty, very usefull info, but my question is about the autocad draw method, what do i need to draw before i can render it.
My 3D pool is ready and now i want to render it.
But i did not draw water, so my question is:
do i have to draw a surface (without any thickness) or schould i fill the whole pool with a solid?
i tried it with a planar surface 100mm below the top of the pool, but it covered my stairs and bottom of the pool??
as you see, trying my best but i am little new in 3D
I've attached a DWG with a water material attached to a 3D solid and a water hatch.
I don't know if the material will work in AutoCAD Lt.......
Whether to draw the water as a solid or surface should be down to your workflow - personally I prefer working with solids.....
3D AutoCAD Pipework - http://www.HerculeDesign.com/
you're right, just testing 3d in autocad 2010
i am a using 2009 LT for flat 2D drawings with toolkit Max
I am looking what softwarepackage is best for me to draw rendered 3D pools. So see it as a test.
There is really no point in creating a solid mass for water unless you need to use it for calculating volume or something. If this is just for rendering purposes, keep it simple and just create a plane and apply a water material to it and then adjust the settings to your liking. You can also apply a bump map to give the water some movement.
Take a look at this thread: http://www.cadtutor.net/forum/showthread.php?t=37463
Dear Hugh_Compton,
I miss the Masonry.Stone.Onyx.Blue.jpg file
Is it possible to send it to me?
ty
Best regards,
Arno (Supernoke)
Hi Arno
I've attached the Onyx.blue file. Sorry, wasn't aware that it was referenced in the DWG.
I would recommend Max for rendering. I have attached a jpg that I just did in 2 mins using some materials that Max comes complete with. You can animate the material by using a simple noise modifier too.
