Results 1 to 8 of 8
    Senior Member
    Inventor 2010
    Jan 2010
    127
    Default Level of Detail vs View in Assembly
    Hello all.
    Can someone give me a run-down and explain to me explicitly what the difference between view and LOD in an assembly is and when do I use what? I'm finding it difficult to determine which to use when creating the views in the drawing ...
    And also, sometimes, when I create a view and hide visibility of a part, I get a message to remove associativity? What is this talking about? Not wanting to stuff something up, I'm forced in this circumstance to create a LOD instead ... but actually, I'm not quite sure what is the difference. I'm primarily wanting to create view/LOD for drawing view puposes and associated functions like BOM in view and nothing else.
    Thanks - David.
    Using Inventor 2010, Build 253, SP1, SP2, SP3, 64-Bit Edition
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    Level of Detail is something that you can use to speed up the performance of Inventor. You can create different level of details with suppressed components(for example) that arent needed for the current operations/view or whatever.
    The error you get in regards to associativity probably has to do with the current model view. For instance if you create a view that is your current model view in the assembly, being associative means that if you go back to the assembly, rotate the parts, your drawing will update. If you remove associativity, it will not.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
    Senior Member
    Inventor 2010
    Jan 2010
    127
    Thanks for the response. So for instance, in a drawing, to create certain views with various parts ommited for clarity purposes etc ... would you create LOD or a view?
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    Quote Originally Posted by linnmaster View Post
    It'a only my opinon but I would use LOD first, and views second. My experience is that, especially when working with large assemblys, LOD's are more stable. Also LOD's can be linked from sub Assemblys to main assembly's.
    I would recomend reserving Views for changing the visual properties of a part or assembly, such as colour for example...
  5. #5
    Senior Member
    Inventor 2010
    Jan 2010
    127
    Thanks for the response Pablo. Colour to me doesn't play much of a role ... as I personally do not bother with colours in my drawings, just black and white, with different line types and thicknesses ... makes things simple.
    What I've found is: For instance, I don't want to show particular items in plan, but I want to show these them in elevation and again something else in end or the projected isometric view, I find that I can select say View1 for elevation, and pick View2 for plan. If I have set LOD1 and LOD2 suppressing various items of the assembly, in the elevation view, if I select LOD1, then the projected plan view also is set to LOD1. I cannot have a different LOD for each view ....
    So then what's the point of LOD?
    Maybe only to improve the performance of Inventor as shift1313 pointed out earlier?
  6. #6
    Inventor 2010
    Feb 2005
    London
    571
    You can have a different LOD for each view. You need to uncheck the link between the parent view and the child views...
  7. #7
    Senior Member
    Inventor 2012
    Mar 2009
    Ohio
    384
    LODs are entirely made up for the sole purpose of system performance in Inventor. Users have developed other ways to use them, but this was the reason they were added. I have consistently come in contact with users and my own designs that number over 10K in total parts. Without LOD and the option to partially open the assembly designer time in canvas is greatly reduced.
    Mark Flayler
    Application Engineer - Manufacturing Solutions Division
    Blog: http://blogs.rand.com/manufacturing/
    Partner Certified, Inventor Certified Expert
  8. #8
    Senior Member
    Inventor 2010
    Jan 2010
    127
    Quote Originally Posted by Pablo Ferral View Post
    Even with the link broken between parent and child view, LOD is greyed out in child view. Only parent view has valid LOD ... at least that is what is happening with me anyways.
    But I think you have to use views .... and I have been able to what I need to do with views with much more ease compared with LOD.
    Thanks for everyone's input.
    Regards,
    David
  1. Detail View?
    By tonika in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2009, 05:58 pm
  2. Changing Zoom Level to view entire drawing
    By CodeSnorter in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Oct 2008, 05:45 pm
  3. Detail instead of Icon view...
    By Flores in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jul 2008, 11:56 am
  4. Detail view
    By clappr in forum AutoCAD General
    Last Post: 8th Jul 2006, 09:15 pm
  5. Level of detail in a drawing
    By asptamer in forum AutoCAD General
    Last Post: 8th May 2006, 04:19 pm
