jagman Posted April 9, 2010 Share Posted April 9, 2010 Sometime during yesterday I stopped being able to see the edit points on any lines or polylines. I can select them, move and copy them, but not edit their shape as I the edit points/handles don't appear. Have I broken something? Thanks Phil Quote Link to comment Share on other sites More sharing options...
Fire_col Posted April 9, 2010 Share Posted April 9, 2010 I doubt very much that you've broken something, type in OP to bring up the options dialogue and go to the 'selection' tab. On there you'll see all the options for your Grips or Handles as you call them. Make sure your grips are enabled and have grip tips enabled, it's entirely up to you if you want grips within your blocks, I find it better to have them enabled as well though. Also check your grip size with the slider bar. Hope this helps. Quote Link to comment Share on other sites More sharing options...
jagman Posted April 9, 2010 Author Share Posted April 9, 2010 Thanks very much - now works fine! Quote Link to comment Share on other sites More sharing options...
Fire_col Posted April 9, 2010 Share Posted April 9, 2010 You're most welcome Phil. Welcome to CADTutor forums. Quote Link to comment Share on other sites More sharing options...
