Results 1 to 8 of 8
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    Default Annotative Breakline (annotation)
    Is there a way to make the Breakline symbol (found in Expresstools) annotative? So it scales according to the Annotation Scale on the lower status bar, and in paperspace.
    edit: I just noticed that Leaders don't work in Paperspace either. Linear Dimensions, however, do.
    Structural
    Structural
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    I'm going to bump this up, because it's been a year.
    I also know that the Breakline is related to the Dimscale. I don't think Dimscale is affected when using Annotative Dimensioning.
    Does this mean that I have to change the Dimscale if I want to make a larger breakline (for plan views vs. details)?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    When I check properties of a break line it is a polyline. It should be scaled with your other line work. Why do you need it annotative?
    Regardless, just make it an annotative block.
    Super Member
    not specified
    Dec 2004
    YUL
    587
    Years ago I wrote my own where the size of a "zig-zag" depends on the length of the first line drawn. Try it, maybe you'll like it.
    Code:
    (defun c:brr (/ p1 p2 p3 p4 p5 p5a p6 d1 d2 d4 dd2 api a1 a2 a3 e1 e2 )
      (command "_.undo" "begin")
      (setq osn (getvar "osmode"))
      (setq oort (getvar "orthomode"))
      (setvar "orthomode" 0)
      (setvar "osmode" 0)
      (setq	p1 (getpoint "\n First point: ")
    	p2 (getpoint p1 "\n Second point:")
      (command "pline" p1 p2 "")
      (setq	d1  (distance p1 p2)
    	d2  (* d1 0.2)	; change the number in this line to adjust the size of zig-zag
    	api (/ pi 180)
    	a1  (angle p1 p2)
    	a2  (+ a1 (* api 63))
    	p3  (polar p2 a2 d2)
    	a3  (+ a1 (* api 284))
    	dd2 (* d2 (sin (* api 63)))
    	d3  (/ (* dd2 2) (cos (* api 14)))
    	p4  (polar p3 a3 d3)
    	p5  (polar p4 a2 d2)
    	p5a (getpoint p5 "\n Third point:")
    	d4  (distance p5 p5a)
    	p6  (polar p5 a1 d4)
    	e1  (entlast)
      (command "pline" "" p3 p4 p5 p6 "")
      (setq e2 (entlast))
      (command "pedit" e1 "j" e2 "" "")
      (command "trim" e1 "" pause)
      (setvar "osmode" osn)
      (setvar "orthomode" oort)
      (command "_.undo" "end")
      (princ "\n Type <  brr > to draw Breakline Symbol: ")
    Edit: Remove the trim feature if you don't like to have it there by placing semicolon in front of this line >
    ;(command "trim" e1 "" pause)
  5. #5
    Structural
    Structural
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    I was going to write a macro to change the dimscale, execute Breakline, then change the dimscale back. Is it true that Macros / Custom Commands only work with a button, and not command line?
  6. #6
    Full Member digger's Avatar
    digger's Computer Details
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    not applicable
    Sep 2010
    N/A
    51
    I don't know if this will help or not, but it is interesting.
    http://www.theswamp.org/index.php?topic=37531.0
    “Absence of evidence is not evidence of absence.” - Dr. Carl Sagan
  7. #7
    Structural
    Structural
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    SLW - an annotative block would require too many clicks. 1 to insert, then 1 for each extension line, plus picking the block. Breakline works well, it's fast and simple.
    Because it appears a macro only works with a button, and I use the keyboard commands, I tried a LISP (which I suck at).
    I can not change the dimscale with Annotative Dimension style. So then I am trying to change the Size and Extension of the Breakline. But when I try the LISP the command line says "unknown command "Breakline"". Which tells me that LISP can't see Express Tools commands? Does that sound right?
    (I am not a member of the Swamp and I need to Log in to see that article)
  8. #8
    Structural
    Structural
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    I ended up creating a macro and a button. It looks like this:
    ^C^Clayer;s;S-HAT;;breakline;s;1/4;e;1/4;\\;breakline;s;1/16;e;1/16;^C^Clayerp
    It changes to my Hatch layer, executes Breakline, changes the Size and Extension, pauses for my 2 points user input, changes the Breakline Size and Extension back to my default (which is suitable for 3/4" scale drawings), then converts to previous layer. It works quite well.
  1. Annotation
    By vertical horizons in forum Autodesk Inventor
    Last Post: 31st Mar 2010, 01:31 am
  2. Annotation
    By peat01 in forum AutoCAD Beginners' Area
    Last Post: 11th Dec 2008, 04:15 pm
  3. Importing Breakline Data.
    By Chanell DP in forum Civil 3D & LDD
    Last Post: 17th Sep 2008, 04:58 am
  4. Customize Breakline?
    By succu8us in forum AutoCAD Drawing Management & Output
    Last Post: 19th Dec 2007, 09:27 pm
  5. Annotation
    By Beale in forum AutoCAD General
    Last Post: 20th Jul 2007, 02:39 pm
