Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Senior Member nowikovs12's Avatar
    nowikovs12's Computer Details
    OS X, windows 7 64bit
    iMac late 2011' 27 inch
    AutoCAD 2013
    Feb 2010
    203
    Default Perspective view
    Hi I set up a camera in perspective viewport, and changed parameters for the camera, to make it look more dramatic, I deleted the camera, and the view still remains the same, and it is hard to work like that, does anyone knows how to reset viewports or change the perspective viewport to how it was originally? thanks
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,416
    If you deleted the camera then the view should have reverted back to Perspective. I don't see how it could still remain in camera view if the camera does not exist?
    But, if you want to change the view in a viewport, right click on the view name in the upper left corner of the viewport and then select the view you want from the pop up menu. Or just hit the key on your keyboard that corresponds with the view you want, such as "P" for Perspective or "F" for Front or "L" for left, etc.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 03/01/2013 ) --->
    http://www.rdeweese.com/
    AutoCAD 2013
    Feb 2010
    203
    Hi, that is strange, when I delete the camera it remais in that sharp angle view, and when I rotate the model its hard to understand, because the perspective looks very stretched, the only way I managed to get close to normal perspective view, is to make a nother camera, select "Dolly Camera" and zoom the lens around, so I get the perspective more or less correct, or maybe I am not deleting the camera correctly, I use fn + backspace on mac keyboard as I use normally when deleting all the items, yes, I use those shortcuts, fast and easy, I also tried the plus button, when looked how reset the perspective view, and under + >view cube>reset front, you can only reset the front viewport, any suggestions?
    AutoCAD 2013
    Feb 2010
    203
    Sorry the shortcut I used for deleting was fn + delete
  5. #5
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,416
    Have you tried saving and closing Max and then restarting it? Maybe something is hung up?
    I don't use a Mac so I don't know what fn + Delete does? Can't you just select the camera and hit Delete?
  6. #6
    AutoCAD 2013
    Feb 2010
    203
    ok, I will try and have a quick test, no on mac keyboard to delete, the only shortcut to delete is fn+delete, just pressign delete doesn't do anything, I will let you know how Im getting on, I will try to delete the camera from the menu toolbar
  7. #7
    AutoCAD 2013
    Feb 2010
    203
    I think I find the problem, I created a camera in perspective viewport, and made the view very dramatic again, then deleted the camera, nothing happened the viewport remained dramatic, then I changed the viewport to front view, and changed it immediately to perspective again, and it is now normal, so for me, when I delete the camera the view doesn't changes immediately, I don't know why, and is it suppose to change immediately? Unless I have different settings, for viewports,...
  8. #8
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,416
    Yes, it should change immediately back to Perspective once you delete the camera. I don't understand why it's not doing that?
    Have you installed all the hotfixes and service packs for your version of Max? I'm not sure if any of them address this issue, but it's always a good idea to install them anyway.
  9. #9
    AutoCAD 2013
    Feb 2010
    203
    I'm not sure if I have all the hotfixes and service packs, where can I see if they are installed, and how do I install them? do I just download them and drag them over in the folder, and reopen 3ds max? thanks
  10. #10
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    3ds Max 2011
    Feb 2006
    Southern California
    8,416
    There is no way to know if the hotfixes have been installed, but if you haven't installed them, they are not installed.
    To find out if the service pack has been installed, go to your Help menu and select "About 3DS Max Design". This will open a window displaying your product information. One of the items at the top is "Release". If the service pack has been installed, it will say something like 12.0 SP1 Commercial. The "SP1" means service pack 1. If it doesn't say SP1, then the service pack is not installed.
    To install the updates, simply save them to your computer. Once they finish downloading, just double click on them to start the installation process. Be sure to close Max before you start installing them though.
    And read the "Read Me" files and make sure you download the correct updates for your operating system. I don't know how these work on a Mac, but on Windows you have 32 bit and 64 bit updates, and you have to make sure you install the correct one.
  1. Use of Perspective View?
    By marlon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jul 2009, 11:50 pm
  2. Perspective view
    By spursnutter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Dec 2008, 01:06 am
  3. perspective view
    By Icarus in forum AutoCAD General
    Last Post: 12th May 2006, 07:49 pm
  4. perspective view
    By richierich in forum AutoCAD Beginners' Area
    Last Post: 2nd Nov 2004, 08:06 pm
  5. 3D Perspective view.
    By Cadastrophic in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Mar 2004, 09:50 pm
