Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2010
    Nov 2009
    Australia
    9
    Default Removing Duplicate Objects
    Hey All,
    I am currently working on a stadium seating floor plan. Just updating things and checking for accuracy. But I have just found that a majority of the seat objects and associated number text on the seat are duplicated. ie if you move one there is another one underneath. So I guess my first question is, would this have any effect on the 'performance' of the drawing. There is 6000 odd seats. So is it processing each seat and number text twice? If it is going to have an adverse effect on performance and is worth cleaning up, is there an easy way to select a whole heap of duplicates, or only the object on top, or something like that? At the moment I have broken it into banks of seating and I am going though and selecting each seat, to only get the one on top, then deleting them. Not very efficient, so I ended up here Any help appreciated
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Try the Express Tools' Overkill command.
    Forum Newbie
    AutoCAD 2010
    Nov 2009
    Australia
    9
    Perfect. Thanks!
  1. Removing an xref clip along with objects outside of boundary
    By nikolai in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2015, 05:22 pm
  2. Removing under laying objects
    By muck in forum AutoCAD General
    Last Post: 5th Aug 2009, 02:00 pm
  3. Removing duplicate and overlapping objects
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 19th May 2009, 07:50 am
  4. Arx Duplicate
    By FIFTHTEXAS in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jun 2007, 02:15 pm
  5. Removing imprinted objects from 3D solids
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 15th Nov 2006, 12:00 am
