vertical horizons Posted April 23, 2010 Share Posted April 23, 2010 In Inventor 2009, where do you change the settings to change which project is the active project? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 23, 2010 Share Posted April 23, 2010 I don't remember exactly in 2009 (my guess would be File>Projects), I do know that you cannot have any files open when changing projects. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted April 23, 2010 Share Posted April 23, 2010 From the "new" pop up you can add, specify active or change project settings. Once you open a document I believe you need to click the drop down(main menu) in the top left. There will be something along the lines of "manage" that should have your project settings. Quote Link to comment Share on other sites More sharing options...
vertical horizons Posted April 24, 2010 Author Share Posted April 24, 2010 Thanks. That was easy enough. This forum is awesome. Quote Link to comment Share on other sites More sharing options...
