deejay500sl Posted April 25, 2010 Share Posted April 25, 2010 Hi, I'm using AutoCad LT 2000, I'm not very experienced. I have 2 lines on top of each other, in different color's black and green. The black line I want to keep and delete the green, but if I select the line and press the delete the black line will be deleted and the green stays. Is there a way to select which line can be deleted? Thanks Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 25, 2010 Share Posted April 25, 2010 Older versions: Holding the control key down will allow you to cycle through a selection. Versions 09 and on, use shift+space bar. Quote Link to comment Share on other sites More sharing options...
deejay500sl Posted April 25, 2010 Author Share Posted April 25, 2010 thank you very much alanjt. Quote Link to comment Share on other sites More sharing options...
alanjt Posted April 25, 2010 Share Posted April 25, 2010 thank you very much alanjt. You're welcome. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 25, 2010 Share Posted April 25, 2010 You can avoid the problem in the first place with the efficient use of layers. Thus, two lines, of the same length, occupying the same space can be isolated by turning off or freezing the layer of one or the other line. It also helps if you do not override layer colors thus ending up with duplicate geometry on the same layer each displayed in a different color. Quote Link to comment Share on other sites More sharing options...
