Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
    Junior Member autocad2010's Avatar
    AutoCAD 2006
    Apr 2010
    11
    Default Plat Map Project
    Hi Guys,
    I'm new here. I have some questions as I finish my project using autocad2006.
    I'm doing a plat project of lots and roads. It asks that I show centerlines on all roads and streets, what does that mean? do I have to use the LTSCALE ?
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    you mean the painted centerlines on the roadways? or a centerline marker for an object?
    AutoCAD 2006
    Apr 2010
    11
    It said:
    Drafting the Plat Map:
    Make a north arrow on the map, show center lines on all roads and streets. I think it means center line marker.
    Then it says: Label all property line bearings, and property line lengths, and all right of way widths.
    XP Pro
    2046 Mb
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    Yeah, I'd agree with that.
    Basically, you just OFFSET the edge of the road to it's center, and give it a new layer/linetype. That's only going to work if the width of the road doesn't vary, otherwise you'll just need to draw a line wherever the center is.
    Of course, I don't know how the streets were initially drawn, and so an offset might not work in your case, regardless.
    LTSCALE will ensure that the dashes and suchlike, in the linetype, show up at an appropriate scale.
    I'd look around for examples to determine what linetypes to use for each thing they're asking you to draw.
  5. #5
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,758
    Default No not the painted ones!!
    Don't forget the crosswalks and stop lines.
    If you have the data points, draw the center line first, then you can just offset the edge of pavement, curb, sidewalk, whatever you need from the center. Then I'd move the different line types to their own layer with the lines and colors already set there.
    It is standard practice to show the physical center of a road on a survey drawing by drawing a Center Line down the middle of it for its entire length. This is the line that is first laid in by the surveyor and everything else measures from it. There are particular line types used in all disciplines of drafting to indicate certain things, and the Center Line is one of the most universal. It looks the same on any mechanical drawing.
    EDIT: I am not sure 2006 has all the following options. I shoulda checked your version before jumping in here, hope some of it helps. You're using 2006? Are you self teaching at work?
    Check your Line Type Control dropdown to see if the Center Line type is there. If not, you will have to load it in from the design center. Click on Other at the bottom of the list, then click Load. Find it on the list and click OK until you have it captured. You can then select the Center Line as your line type. I would create a separate layer just for your center lines. You will need some arcs with the same line type as well. You will probably have to play with ltscale to get it so you can see the breaks in the lines. You will have a short line between two breaks every so often.
    I probably should not have given all the details, but you have your hands full with a survey drawing anyway. Good luck.
    EDIT: I was assuming you are a student.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  6. #6
    AutoCAD 2006
    Apr 2010
    11
    Yes, I'm a distant student doing the auto cad at Penn drawing the oleson village plat map.
    You are right, I did make a centerline layer that's already dashed. But the question is how do I make it in the middle of the road? and how to make it turn around the arcs?
  7. #7
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2014
    Dec 2008
    Rancho Cordova, CA
    541
    Typically on plat maps the centerline of a road is the center of the right-of-way. The road usually centers on this same centerline but that is not always the case. In the case of interstate highways, state highways, etc. the centerline of the road can be quite different than the right-of-way centerline. Also centerlines only have arcs in them if the road has a curve. If they intersect with another road then the centerline terminates at the centerline of the road it intersects with.
    Roadway delineations (ie. painted markings) are not always the center of the road either. Although typically they are.
    Calvin
    Soli Deo Gloria
  8. #8
    AutoCAD 2006
    Apr 2010
    11
    I have 2 arcs, a road that bends, and a road that intersects with another road with a fillet. So how do I make the centerline for it?
  9. #9
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    What roads are you having problems with?
  10. #10
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    If you scroll to the bottom of this thread you will see other referances to this same drawing.
  1. Project: Plat Map ~ Help please
    By Brynn in forum Student Project Questions
    Last Post: 12th Nov 2011, 07:47 pm
  2. Curve in Plat Map Coordinates
    By ljstevens in forum AutoCAD General
    Last Post: 11th Mar 2008, 12:21 am
  3. Reading a plat
    By Son of Aslan in forum AutoCAD General
    Last Post: 17th Feb 2008, 06:05 pm
  4. Scanned Plat
    By UsedCrayons in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2007, 01:01 am
  5. Trying to show bearings/distances on plat.
    By huntman23 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2006, 11:09 pm
