Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
  1. #11
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2014
    Dec 2008
    Rancho Cordova, CA
    541
    Quote Originally Posted by autocad2010 View Post
    I have 2 arcs, a road that bends, and a road that intersects with another road with a fillet. So how do I make the centerline for it?
    For the road that bends the radius of the curve is based on the traffic speed for the road. But since this doesn't matter here (I assume) then using the fillet command with a radius will work. For the one that intersects with another road, just end the line of the intersecting road at the centerline of the road it intersects. (ie. just like a T.) Roads that intersect do not have any curves in them. The right-of-way lines that are around them might have arcs at the corners of the lots though.
    Calvin
    Soli Deo Gloria
  2. #12
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    Windows 10
    Some Gateway junk from 7 years ago
    i5
    8gb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    AutoCAD 2014
    Mar 2010
    Clearwater, Florida
    559
    offset.. like I said earlier.. it doesn't matter if it's a line or an arc.. offset to the center.
  3. #13
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Yes Mike, that is what I did when I drew the same plat map.
  4. #14
    Junior Member autocad2010's Avatar
    AutoCAD 2006
    Apr 2010
    11
    How do I label property line bearings, and property line lengths, and all right of way widths.
  5. #15
    Windows 7
    12 gig
    Nvidia Quadro 600
    237 GB
    Civil
    Civil
    Civil 3D 2014
    Dec 2008
    Rancho Cordova, CA
    541
    You will have to label them manually unless you have Civil 3D or Land Desktop. There maybe a lisp routine lurking on this forum to help automate the labeling.
    Calvin
    Soli Deo Gloria
  6. #16
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Here is a screen shot of parts of the drawing.
    I think this will answer some questions.
  7. #17
    AutoCAD 2006
    Apr 2010
    11
    This definitely helped!! Thank you my friend.
    So those small arcs I can make them, and then I would just put the total length of each side on those lots? Or should I use lisp?
    Also I noticed you placed S3w, do I need to post those as well?
  8. #18
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    If you use a lisp you will have to redraw the plat map, and the max score you will get is a 75%.
    I think you haven't read the instructions through. The instructions are out of sequence with the information as givin and the draw order.(This is how your tested to see if you read the instructions)
    Work the instructions line by line. It will tell you were to put everything.
    Just make sure your bench Mark and POB are correct. DO NOT change the drawing limits or you will loose points. (I have first hand experiance there.)
  9. #19
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    I forgot to mention that the small arcs you are refering to are referanced in the drawing samples in the referance material.
  10. #20
    AutoCAD 2006
    Apr 2010
    11
    I'm trying to resize the trees, but I noticed that when I use the scale w, I scale (resize) the lines as well. I do have a tree block, when I insert it, only one tree shows, but in the plat, I can see all the trees there. Did I do the block wrong?
  1. Project: Plat Map ~ Help please
    By Brynn in forum Student Project Questions
    Last Post: 12th Nov 2011, 07:47 pm
  2. Curve in Plat Map Coordinates
    By ljstevens in forum AutoCAD General
    Last Post: 11th Mar 2008, 12:21 am
  3. Reading a plat
    By Son of Aslan in forum AutoCAD General
    Last Post: 17th Feb 2008, 06:05 pm
  4. Scanned Plat
    By UsedCrayons in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2007, 01:01 am
  5. Trying to show bearings/distances on plat.
    By huntman23 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2006, 11:09 pm
