Dont snap to Locked Stuff! / Lock a block or Object!
TimZilla
Two questions!
First: Is there a way to set up your osnaps so that they do not snap on on stuff that is locked?
Second: Is there a way to lock a block or object without locking the whole layer?
If I could figure both of these things out I would save a lot of time.
Sometimes I just have way to much stuff in my drawing, most of it is for reference and I never need to snap to it, I need to see it, but I hate that it picks up my snaps. Drives me crazy.!
  • Replies 47
  • TimZilla
    18
  • alanjt
    16
  • ReMark
    6
  • Lee Mac
    5
I think this is in the wrong section.. Though it DOES say customization..
However, just in-case it helps any.. the Osnaps automatically "prefer" the current drawing layer. Perhaps that's enough?
Otherwise, you can fine tune the selection process by adjusting the size of the selection box in your Drafting settings (in options).. I'm not sure of any settings that do what you're asking, but I'm on older cad, so who knows.
yeah, i tried adjusting the size, didn't work for me. I am hoping that some genius develops a lisp command just for me and I can say, YAAAY!, thank youz!
how about locking an object, instead of a layer?
Am I the only one this would help? It has to exist.
the osnaps prefer current wouldnt help, but it would help if it just didnt snap to stuff thats locked.
I put all of my walls and doors in one layer/one color.
HVAC/Mechanical in one layer/one color.
Electrical in one layer/one color.
Ceiling Grid in one layer/one color
and so on.
Then, I lock most of it and it makes it faded. So that when I draw my stuff, being the Sprinkler System. My stuff stands out. If I could only figure a way to keep my osnaps from jumping to certain things, although not everything. Just wish I had an option to pick. Even an option to keep osnaps from sticking to certain layers would be cool, if the locked layer thing wouldnt work. Something.
This is the best I can think of for the moment - but its a bit risky :(
(defun c:VisTog ( / tmp )
 ;; Lee Mac  ~  27.04.10
 (if (or (and *ss* (not (setq tmp *ss* *ss* nil)))
         (and (setq tmp (ssget)) (setq *ss* tmp)))
   ( (lambda ( i / e )
       (while (setq e (ssname tmp (setq i (1+ i))))
         (Update
           (PutDXF 60
             (- 1 (cond ((cdr (assoc 60 (entget e)))) (0)))
             (entget e)
     -1
(defun PutDXF ( code value elist )
 (entmod
   (if (assoc code elist)
     (subst (cons code value) (assoc code elist) elist)
     (append elist (list (cons code value)))
(defun Update ( elist )
 (entupd (cdr (assoc -1 elist)))
So, I should probably do my testing at home and not at work ehh? can't afford to lose a days work by messing anything up.
also, thanks for the "double no"
I would be willing to bet it can be done. Anything can be done in autoCAD. It seems like every time I have an idea, somebody has already created something for it. I love AutoCAD. I am such a nerd. But I just love it.
A lot of the vertical versions of AutoCAD has the object isolate/hide option built in. Actually, I think newer version of ACAD have added this to the core.
It's not really 'locking' individual objects though.
   ( (lambda ( i / e )
         (Update
           (PutDXF 60
             (entget e)
     -1
 (entmod
My code won't damage your drawings at all, it just switches Object Visibility, but its risky in the fact that some people may not know how to switch back on Object Visibility if it goes wrong.
This function will make everything visible again :)
(defun c:AllVis ( / tmp )
 (if (setq tmp (ssget "_X"))
   ( (lambda ( i / e )
         (Update
           (PutDXF 60 0 (entget e))
     -1
 (entmod
Lee
My response wasn't meant to be smarmy. I'm honestly telling you that it can't be done. What Lee provided will HIDE an object, not 'lock' it. What you are asking goes against the basic structuring of AutoCAD.
The only way you are going to achieve this is to put an object reactor on it, but that is beyond insane.
And what happens when a person opens this drawing and doesn't have a way to make all objects visible or know that such a thing is possible?
Hide Objects (AutoCAD 2010)
Temporarily hides selected objects for the current drawing session.
There is also an Isolate Ojects command. Notice there is no mention of locking objects so they cannot be selected.
Fair point Alan, as I said, it was risky.
And I didn't know about those ReMark, but just for completeness, these are probably better than a toggle:
   ( (lambda ( i / e )
         (Update
     -1
(defun c:Invis ( / tmp )
 (if (setq tmp (ssget "_:L"))
   ( (lambda ( i / e )
         (Update
           (PutDXF 60 1 (entget e))
     -1
 (entmod
But I prefer your solutions.
Thank you.
I know, but sometimes I think you are too quick to post a possible solution of code. When something is considered risky, perhaps it's better left alone.
Well, Fire Sprinkler Designers make up about .00001 % of the CAD world, so I understand there is not a lot of stuff built for us. We have to follow our codes while working around other peoples crap. Very difficult. We get that left over space to work in, yet perfection is expected. Thats why you will notice I ask some pretty weird stuff. 98% of the time you people are very helpfull, and I usually make toolbar buttons out of the lisp's I get here. I have a lot of good stuff that speeds my day up.
.....waiting for the "what do you mean "YOU PEOPLE" comment"
Could you turn off your sprinkler stuff do a JPGOUT to create a JPG of the background. Insert the JPG and verify location and scale, then freeze off everything except your jpg and your sprinkler layer.
When you're done, detach the jpg and thaw the structure and you are back to where you want to be.
Glen
Glen
turns into a big blob.
