CCHESTER Posted April 27, 2010 Share Posted April 27, 2010 My google earth image hides my drawing. I pasted it into my cadfile then scaled it accordingly. The problem now is that it covers the entire dwg i can only see my layout when its selected. How can i fix this? Quote Link to comment Share on other sites More sharing options...
BWells Posted April 27, 2010 Share Posted April 27, 2010 the problem your running into is the fact that you have a massive JPEG in the way of your drawing. best bet would be to (i know this sounds silly, but i just want to be sure) make sure the image is in model space and aligned correctly and then turn the image off with the properties bar. from there you can work on the drawing and turn it back on when your ready. you may not be able to see the lines before you print but rest assured they are there. they should show up in the print preview. (make sure the image is sent to the back though.) if not then the issue would be a line weight issue and that my friend is a different beast. Quote Link to comment Share on other sites More sharing options...
