Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,281
    Default Fraction Format With Dimension Text Override
    I am using the following in the text override field for a dimension:
    3'-8\S1/2"
    And this creates 3'-8 1/2" with the fraction as a horizontal format. What I want is a diagonal format for the fraction. What is the proper syntax for this.
    It's deja vu, all over again.
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Like this (forgot the hyphen)?
    You can just type the "1/2", highlight>right-click>choose Stack. Is this what you are trying to accomplish?
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,281
    Thanks but that doesn't really work in my application. I'm making this text entry in the text override window of the properties window.
    The attached file shows what I'm talking about. I would like for the fraction in the dimension appear like the diagonal fraction in the text. Right now the only way I can get the fraction in the dimension is to use the text override feature and this ends up with a horizontal fraction, not a diagonal one.
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    This'll do it: 3'-8\S1#2"
  5. #5
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,281
    Ah, I now see how it's done. Thanks guys. This is going to make my life simpler in the future.
  6. #6
    Forum Newbie
    AutoCAD 2010
    Sep 2010
    1
    Default Help with creating own stack dimensions.
    Bill - Thank you for this post, but I have a question::
    Did you ever figure out how to get out of fraction mode?
    Ie. You typed... 3'-8\S1#2"
    How do you get the inches (quotation mark), which stays at the bottom of the 1/2", and get it back up in line with everything else?
    Thanks for your help on this!
  7. #7
    Forum Newbie
    AutoCAD 2010
    Mar 2010
    2
    Quote Originally Posted by will_the_arch View Post
    bill - thank you for this post, but i have a question::
    Ie. You typed... 3'-8\s1#2"
    how do you get the inches (quotation mark), which stays at the bottom of the 1/2", and get it back up in line with everything else?
    3'-8\s1#2;"
  8. #8
    Forum Newbie
    Architecture 2008
    May 2008
    3
    I realize this is an old thread and apologize but...
    Thanks for the info, all very helpful. Hopefully you can help a bit more:
    Is it possible to have the fraction scale down to 70% as is done in non-overridden fractional dimensions and MTEXT? As-is, this works well but looks a bit off if this technique is used in conjunction with 'actual' fractional dimensions.
  9. #9
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    You can use the text editor on dimension text with _DDEDIT.
  10. #10
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by SLW210 View Post
    or type "ED"
    DropBox
  1. Dimension Lisp that promts a text override.
    By MikeP in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2009, 05:11 pm
  2. Copy dimension to text override
    By MikeT in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jan 2009, 10:27 am
  3. Override dimension
    By mdbdesign in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2007, 03:14 am
  4. Text Override with fraction
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2006, 03:35 pm
  5. %%201, %%202 and so on.... Fraction Dimension
    By richjenn03 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2005, 10:51 pm
