jitupnair Posted April 29, 2010 Share Posted April 29, 2010 Hi, I need to extend a closed polygon, Can some one make a lisp program for me. Thanks & regards Jithesh P. Nair Quote Link to comment Share on other sites More sharing options...
MarcoW Posted April 29, 2010 Share Posted April 29, 2010 Hi,I need to extend a closed polygon, Can some one make a lisp program for me. Thanks & regards Jithesh P. Nair Hello Jithesh P. Nair, First of all welcome to the CADTutor Forum! You might wanna check out these links, over at the neighbours from the swamp: http://www.theswamp.org/index.php?topic=26111.0 http://www.theswamp.org/index.php?topic=30650.msg378483#msg378483 Maybe that these can help you out. Good luck! Regards, MarcoW Quote Link to comment Share on other sites More sharing options...
jitupnair Posted April 29, 2010 Author Share Posted April 29, 2010 Thanks Marcow, The first link program is for stretching the polylines. It will change the property of the polygon if it ends with an arc. Second link was extending but giving error and in the arc segments it behaves differently. I dont know the reason. I am using AutoCAD 2009 So I need a program that will extend the polygon Thanks & regards Jithesh Quote Link to comment Share on other sites More sharing options...
