alnabhani Posted May 1, 2010 Share Posted May 1, 2010 hellow, i want to make a threaded shaft using design accelerator, and then i want to make a threaded cylinder that the shaft will go inside as can be seen in the link : what i want to do is to rotate the threaded rod in order to make the cylinder sliding on the shaft - i mean appliyng torque in a dynamic simulation . how i can do that ? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 1, 2010 Share Posted May 1, 2010 Attach your assembly here. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted May 1, 2010 Share Posted May 1, 2010 hellow, i want to make a threaded shaft using design accelerator, and then i want to make a threaded cylinder that the shaft will go inside as can be seen in the link : what i want to do is to rotate the threaded rod in order to make the cylinder sliding on the shaft - i mean appliyng torque in a dynamic simulation . how i can do that ? Check out this thread. http://www.cadtutor.net/forum/showthread.php?t=45548&page=4 on page 4 i explained how to animate this in dynamic simulation. If you start at page one it goes through making the threads as well. Quote Link to comment Share on other sites More sharing options...
