Check your bends.
Certified SolidWorks Professional
Autodesk Inventor 2013 Certified Professional
Autodesk AutoCAD 2013 Certified Professional
http://home.pct.edu/~jmather/content..._Tutorials.htm
Hey Shift, what would be the most efficient technique of reproducing attached in SolidWorks? (pull down the EOP)
Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
Current Software: SolidWorks11,SolidCam11
http://www.solidworkslessons.info/
www.mysolidbox.com
Thats the badger. I had a play with the mitre flange technique but was unable to get the clearance between the flanges small enough. What JD has drawn looks interesting though. How did you produce it, I cant open the attached IPT file, my Solidworks says I have the wrong inventor type.
Here is a STEP file of my solution. Only took about 5 minutes in Inventor. I'm still trying to figure out how to get it in SolidWorks without a lot of work.
www.mysolidbox.com
Well I plaed a bit more and got it but matt beat me to the solution.
Here is mine, now I'll go take a look at Matt's.
Last edited by JD Mather; 4th May 2010 at 07:45 pm. Reason: Never mind - I got it to rebuild
shame on you JDsketch fillets and an under defined sketch
www.mysolidbox.com
Thanks for that Mat. I shall have a proper look again at my effort, and see where I am going wrong. Last time I worked in inches, I was working in a shipyard that is now a development of exclusive flats?![]()
Thanks also JD, Ive only been using SW for 4 years now, so I guess I have a long way to go yet.![]()
