+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
  1. #11
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,719
    Default
    Check your bends.
    Certified SolidWorks Professional
    Autodesk Inventor 2015 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
  2. #12
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,719
    Default
    Quote Originally Posted by Ubatoid View Post
    dutch fold (over and flat, hem) all round
    Is something like this what you are after (half split away).
  3. #13
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,719
    Default
    Hey Shift, what would be the most efficient technique of reproducing attached in SolidWorks? (pull down the EOP)
  4. #14
    Forum Deity shift1313's Avatar
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    3,249
    Default
    Quote Originally Posted by JD Mather View Post
    I would still use a miter flange. You can select all 4 edges at once and it will make that part. Its the same as a contour flange in inventor. I am curious though, is there a reason you split the solid instead of using Section on the Inspect tab?
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks17,Mastercam2017, fusion360, Inventor 2017, HSMworksUltimate
    http://www.solidbox.tv Free and Paid Tutorials for Solidworks, Mastercam and Fusion360
    http://www.mysolidbox.com/ CAD and CAM optimized workstations and laptops
  5. #15
    Junior Member
    Using
    not applicable
    Join Date
    Apr 2010
    Posts
    15
    Default
    Thats the badger. I had a play with the mitre flange technique but was unable to get the clearance between the flanges small enough. What JD has drawn looks interesting though. How did you produce it, I cant open the attached IPT file, my Solidworks says I have the wrong inventor type.
  6. #16
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,719
    Default
    Here is a STEP file of my solution. Only took about 5 minutes in Inventor. I'm still trying to figure out how to get it in SolidWorks without a lot of work.
  7. #17
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    3,249
    Default
    It works just fine for me. I set my gap down to .01" with no issue. What gap are you trying to achieve? You can use the closed corners to tighten up the edges if needed. I uploaded the one i just made. drag the end of part line down after you unzip the file.
  8. #18
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,719
    Default
    Well I plaed a bit more and got it but matt beat me to the solution.
    Here is mine, now I'll go take a look at Matt's.
    Last edited by JD Mather; 4th May 2010 at 07:45 pm. Reason: Never mind - I got it to rebuild
  9. #19
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    3,249
    Default
    shame on you JD sketch fillets and an under defined sketch
  10. #20
    Junior Member
    Using
    not applicable
    Join Date
    Apr 2010
    Posts
    15
    Default
    Thanks for that Mat. I shall have a proper look again at my effort, and see where I am going wrong. Last time I worked in inches, I was working in a shipyard that is now a development of exclusive flats?
    Thanks also JD, Ive only been using SW for 4 years now, so I guess I have a long way to go yet.
Similar Threads
  1. Printed Drawing size to fold into A4
    By Hormell in forum AutoCAD Beginners' Area
    Last Post: 10th May 2011, 09:34 pm
  2. How to fold and unfold in 3D
    By ASchroederIV in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Nov 2010, 04:54 pm
  3. Double Trouble! (Help on Double Doors Drawing)
    By Numerics in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2010, 03:13 am
  4. Double Lines
    By Tostrhed in forum AutoCAD Beginners' Area
    Last Post: 19th Oct 2008, 10:18 pm
  5. Dutch gable roof in ADT 2005...possible? Driving me crazy!
    By stir-crazy in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2007, 05:51 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
