cadamrao Posted May 3, 2010 Share Posted May 3, 2010 Hi I’m using civil 3D 2010.I created corridor 1, corridor 2 and also intersection; please help, how to join (corridor 1, corridor 2 and intersection) a single section. Plz guide me steps how to do this Thanks Amr Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 4, 2010 Share Posted May 4, 2010 We dont use corridors but another addon but I would expect proceedure is the same. using corridor 1 update your surface model to reflect changes save as surface 2. have corridor two resample new surface and then update surface to reflect changes save as surface 3 using intersection now update surface 3 and save as surface 4 Updating 1 surface at a time and resampling can give a better final model versus just pasting all corridors in one go. Save each surface as you can delete at any time and it makes it easier if a surface combine doesn't work right. Hope this helps Quote Link to comment Share on other sites More sharing options...
sinc Posted May 4, 2010 Share Posted May 4, 2010 Is there a particular reason you used three Corridors? The usual practice is to use one Corridor, unless you have a very complex site with flyover ramps, etc., and you have to split up your design into multiple Corridors. What do you mean by "join to a single section"? Do you simply want to combine the surfaces? Or are you talking about something else? Combining the surfaces should be as easy as creating a new surface, and pasting your Corridor surfaces into it. If you're talking about cross-sections and stuff like that, then things might get more involved. Quote Link to comment Share on other sites More sharing options...
