Results 1 to 5 of 5
Thread: Wacky Wires
    Full Member
    AutoCAD 2010
    Apr 2010
    84
    Love Wacky Wires
    I got an Electrical wire plan to draw out, while i do have the symbols created, this picture does not indicate the length of the wires (red), is there any way for me to know how long they are without guessing?
    BTW that is a preview window, not AutoCAD itself, so i cannot transfer that image elsewhere to decide, nor does the description for the image say anything about the measurements, just to create it.
    -thanks
    Last edited by Numerics; 4th May 2010 at 05:43 pm. Reason: forgot the image, durr.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    A schematic is drawn to look aesthetically pleasing - there is no "correct" length. Use the Design Center symbols (or Autodesk Seek) or the resistors, capacitors and transistor and scale the rest of the schematic to look proportional. This should have been covered in your class.
    Full Member
    AutoCAD 2010
    Apr 2010
    84
    Quote Originally Posted by JD Mather View Post
    A schematic is drawn to look aesthetically pleasing - there is no "correct" length. Use the Design Center symbols (or Autodesk Seek) and scale the rest of the schematic to look proportional.
    oh, well that's good to know, thank you ^^
    and what is Autodesk Seek?
    or Design Center?
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Numerics View Post
    or Design Center?
    Google Autodesk Seek - a site with predefined gemetry. ...Autodesk Seek, a powerful, dynamic web service that replaces bulky paper catalogs and static online directories....
    Design Center - built in library of predefined Geometry (like electonic symbols). F1
  5. #5
    Full Member
    AutoCAD 2010
    Apr 2010
    84
    ok, thank you again
  1. wacky scrolling
    By chelsea1307 in forum Software & Licensing
    Last Post: 6th Oct 2009, 06:09 pm
  2. Wacky UCS
    By Bill Tillman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Nov 2008, 12:40 pm
  3. Creating wires
    By CADken in forum SketchUp
    Last Post: 25th May 2007, 07:12 pm
  4. To calculate forces in ropes/wires
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jun 2006, 04:42 pm
  5. wacky system variables...
    By originalsurfmex in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2006, 10:53 pm
