Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2011
    Apr 2010
    England
    7
    Default Dimensions on a isometric circle
    Currently using autoCAD 2009. The problem i am having is that i can't find a way to annotate the radius or circum of a isometric circle.
    Is there any to do this? thanks
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    Windows 10
    Some Gateway junk from 7 years ago
    i5
    8gb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    AutoCAD 2014
    Mar 2010
    Clearwater, Florida
    559
    I suggest you fake it with a Qleader and manually put the dimensions on there.
    To you, that's a circle shown on an angle.
    To AutoCAD it's an ellipse which isn't really a circle or arc in it's book, it holds multiple faked radius measurements, rather than just the radius/diameter you used to make it with.
    If you manually measure it, you'll notice that the distance from centerpoint to edge is going to give you a different radius depending upon the angle of your line.
    The Circumference isn't going to show up either.. Even if it did.. it'd be the circumference of an isometric circle, not of the actual circle you intended to get those measurements from.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    I don't know of any good way of doing this in AutoCAD. If your work in mechanical this is automatic in Inventor.
    Windows 10
    i5
    8gb
    AutoCAD 2014
    Mar 2010
    Clearwater, Florida
    559
    The other way is to do it in 3d, and view it from an isometric angle... Then the circle dimensioning commands will work.
    JD? Does Inventor supports isometric drawing, or did you mean do it in 3d in Inventor?
  5. #5
    Forum Newbie
    shaikhrulez's Computer Details
    Windows 7
    Core 2 Duo
    AutoCAD 2006
    Nov 2010
    Pakistan
    2
    There is a way to measure ISOMETRIC circle .. !! 1st make a line from the centre of the circle and extend it out of the Quardent point of the circle .. then you will be able to measure the radius of that circle . !!
  6. #6
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by shaikhrulez View Post
    Can you post an example illustrating this technique?
  7. #7
    Forum Newbie
    Windows 7
    Core 2 Duo
    AutoCAD 2006
    Nov 2010
    Pakistan
    2
    Here i was made a Isocircle having Radius of 12. and you can see how can i check the radius.
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    That is pretty ugly if you ask me. I would rather use a call out.
  9. #9
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,596
    They said CHECK the size, not show dimensions. Shouldn't be necessary if it is your own drawing.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  10. #10
    Super Member fahim108's Avatar
    fahim108's Computer Details
    Windows XP Professional
    HP Pavilion dv5000
    Architectural
    fahim108's Discipline Details
    Architect
    Architectural
    AutoCAD 2016
    Apr 2006
    Mumbai, India
    501
    A vertical (linear) dimension should be easier to snap rather than a 30° rotated dimension; and moreover, it doesn't look that ugly...
  1. Circle-Isometric Snap
    By Shibuboss in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Aug 2009, 01:41 am
  2. Dimensions in isometric
    By DODGE in forum AutoCAD General
    Last Post: 2nd Apr 2009, 10:25 pm
  3. Dimensions for Isometric Objects
    By happyunited in forum AutoCAD General
    Last Post: 19th Jul 2008, 12:53 am
  4. ...draw isometric dimensions?
    By Skins in forum AutoCAD General
    Last Post: 2nd May 2007, 11:15 am
  5. Circle in isometric projection/drawing.
    By whel_13 in forum Catch All
    Last Post: 15th May 2003, 04:46 am
