arraying attributes
AJSmith
can it be done i want the information in attributes to appear a number of time down a block as its size in increaced
cheers
Adam Smith
its not recommended. If you array an attibute it takes its TAG with it. While AutoCAD no longer goes off in a huff if you have the same attribute tag several times in the same block it will make any future LISP/VBA routine you throw at it run round in circles with unpredictable results.
