Results 1 to 8 of 8
    Full Member
    AutoCAD 2007
    May 2010
    31
    Default is there a command to draw a line with an angle to an inclined line?
    there is an existing inclined line,to say 26 degree to horizental,if i want to draw a line who has an angle 12 degree betwwen those two lines.
    the method i always do is firstly to measure the first line's angle from horizental,and then add the two angle,then draw what i want
    but i think there maybe a command i do not know or tricks i can do this faster,for example,if what i have to do is to input the angle+click the inclined line+click a point as the corner would be helpful!
    Super Moderator
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,478
    You could use polar tracking after adding an additional angle of 12° (or whatever you need).
    R.K. McSwain
    CAD Panacea | twitter
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,103
    One simple way, is to copy the line, and then rotate one of the lines by the required angle.
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    Or, if you want to bisect an angle.. (without knowing the angles, or a desire to avoid the math) draw a circle or arc using the intersection of the two angles as the centerpoint.
    Use the two angles to trim it down to where it's an arc starting and stopping at the lines.. Then draw a line from the midpoint of that arc to the centerpoint of that same arc.
    That's how you do it in sheet metal layout geometry... If the two lines of the angle are the same length, you can just draw a line from endpoint to endpoint instead, and use the midpoint of that line.
  5. #5
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by eldon View Post
    In newer versions, Rotate even has copy as a built in option.
    Code:
    ROTATE
    Current positive angle in UCS:  ANGDIR=counterclockwise  ANGBASE=0d0'0"
    Select objects: 1 found
    Select objects:
    Specify base point: ENDP
    of
    Specify rotation angle or [Copy/Reference] <12d0'0">: C Rotating a copy of the
    selected objects.
    Specify rotation angle or [Copy/Reference] <12d0'0">: *Cancel*
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  6. #6
    Super Moderator
    Windows 7 Pro x64
    HP ZBook 17
    16GB
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,478
    Quote Originally Posted by alanjt View Post
    And in older versions too (back to R12 I think) if you use grips.
    R.K. McSwain
  7. #7
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by rkmcswain View Post
    Oh yeah. Excellent addition.
    DropBox
  8. #8
    Full Member
    AutoCAD 2007
    May 2010
    31
    thank you all for your reply.i think 'rotate' is really a good method to do what i want,but why didn't i notice such a trick?i have ever thought to write an autolisp function to do the job,but i have never written any program using autolisp,i read books on it,and found it rather possible
    i think there is a 'getangle' standard function to get the first angle,but i do not know why it seems the degree of the angle is transfered into rad's,why?after getting the angle,i want to use the 'snapang' command,but it seemingly doesn;t work,
  1. How do i draw line at specific angle?
    By nbaryosef in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Jan 2013, 07:54 pm
  2. A command to draw a line from near to perp
    By eelywig in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Nov 2009, 07:46 pm
  3. lisp to draw line on same angle as line picked
    By john_ in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2009, 03:32 pm
  4. draw a line using VBA with an angle and a length?
    By wbluem88 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Aug 2008, 06:07 pm
  5. Command to draw line then change the scale
    By raj banerjee in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Aug 2007, 04:47 pm
