Results 1 to 4 of 4
    Forum Newbie
    Architecture 2009
    Oct 2009
    3
    Angry Material not showing in render scene
    I have a fairly basic model sitting on a slab with a grass material applied to it, and 8 camera's placed around the structure all at the same height and with the same lens length.
    However while rendering the scene's from the camera views, some of them do not show the grass material or only partially show it,
    (see attached images)
    any help or ideas?
    Q
    Super Member MikeScott's Avatar
    MikeScott's Computer Details
    XP Pro
    Dell Precision T3400
    2.67 gigahertz Intel Core2 Duo
    2046 Mb
    NVIDIA Quadro NVS 290/ 256MB DDR2
    ST3500418AS/ 500gb (450gb free)
    DELL G2410 (24.0"vis)
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    Could it be the "reflection" and "roughness" values conspiring to show the color instead of the material? Set the reflection color to another green tint, perhaps?
    I would add the grass in "post" (ie- in an image editor, after-the-fact), if it still gives you trouble. Or make it part of the background.
    Forum Newbie
    Architecture 2009
    Oct 2009
    3
    Yes applying the grass material post process may be an answer,
    however if it was the reflection or roughness values, or any other settings for that matter, surely it would be a uniform defect,
    I don't understand why this is only happening from certain angles/camera's
    XP Pro
    2046 Mb
    AutoCAD 2004
    Mar 2010
    Clearwater, Florida
    558
    The relative angle from lightsource, to the object, to the camera would change it.
  1. Render Material
    By vinod in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jul 2009, 12:19 pm
  2. "Error allocating mesh. Reduce the face count to render this scene"
    By Lora_D in forum Cameras, Lighting & Rendering
    Last Post: 17th Dec 2008, 04:00 pm
  3. Render material not works
    By Leech in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Dec 2006, 03:04 pm
