Results 1 to 6 of 6
    Junior Member
    AutoCAD 2008
    Oct 2009
    22
    Question Hideprecision set to 1 before plot?
    How can i set hideprecision to 1 before i plot? then set it back to 0 after it plots? im told i could use a reactor but im not that far into my lsp skills yet, any help would be much appreciated!
    i just found this but i dont quite get it
    HTML Code:
    (defun CommandReactor (objReactor lstCommand)
     (cond
      ((= (car lstCommand) "PLOT")
       (print "\nDo stuff before plot: \n")
    (setq rxnCommand ( vlr-editor-reactor nil '((:vlr-commandwillstart .  CommandReactor))))
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Perhaps
    Code:
    (setvar 'HIDEPRECISION 1)
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Junior Member
    AutoCAD 2008
    Oct 2009
    22
    well i have this but it not working
    HTML Code:
    (defun edgplotstart (objReactor lstCommand)
    (cond
     (print "\n Hideprecision Set to 1")
    (setvar "hideprecision" 1)
    (setq rxnCommand ( vlr-editor-reactor nil '((:vlr-commandwillstart . edgplotstart))))
    (defun edgplotend (objReactor lstCommand)
    (cond
    (print "\n Hideprecision Set to 0")
     (setvar "hideprecision" 0)
    (setq rxnCommand ( vlr-editor-reactor nil '((:vlr-commandended . edgplotend))))
    well i dont think its working
    HTML Code:
    Command: _plot
    "\nHideprecision Set to 1"
    "\nHideprecision Set to 0"
    "\nHideprecision Set to 1" Effective plotting area:  10.60 wide by 15.91 high
    Effective plotting area:  5.69 wide by 1.05 high
    Plotting viewport 2.
    Effective plotting area:  5.70 wide by 1.71 high
    Plotting viewport 3.
    Plotting viewport 1.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Try this:
    Code:
    (defun c:HidePrecReactor nil
      (vl-load-com)
      ;; Lee Mac  ~  07.05.10
      (  (lambda ( data / react )
           (if (setq react
                 (vl-some
                   (function
                     (lambda ( reactor )
                       (if (eq data (vlr-data reactor)) reactor)
                   (cdar
                     (vlr-reactors :vlr-command-reactor)
             (if (vlr-added-p react)
               (vlr-remove react)
               (vlr-add react)
             (setq react
               (vlr-command-reactor data
                 (list
                   (cons :vlr-CommandWillStart 'SetHide)
                   (cons :vlr-CommandEnded     'RestoreHide)
                   (cons :vlr-CommandCancelled 'RestoreHide)
           (princ
               "\n** Reactor Activated **"
               "\n** Reactor Deactivated **"
           react
        "Prec-Reactor"
    (defun SetHide ( reactor params )
      (if (eq (strcase (car params)) "PLOT")
          (setq oldHide (getvar 'HIDEPRECISION))
          (princ (strcat "\n<< HIDEPRECISION set to 1 >>"))
    (defun RestoreHide ( reactor params )
      (if (and oldHide (eq (strcase (car params)) "PLOT"))
          (setvar 'HIDEPRECISION oldHide)
          (princ (strcat "\n<< HIDEPRECISION set to " (itoa oldHide) " >>"))
          (setq oldHide nil)
    Turn on the reactor using HidePrecReactor (turn it on once), and turn it off with the same command.
  5. #5
    Junior Member
    AutoCAD 2008
    Oct 2009
    22
    nice!! man your badass, i was telling my friend about you lol (hes the one teaching me lisp)
    it is getting caught at here
    HTML Code:
    (and oldHide (eq (strcase (car params) "PLOT")))
    i changed it to
    HTML Code:
    but something is still happening funny so i just made it
    HTML Code:
          (setvar 'HIDEPRECISION 0)
          (princ (strcat "\n<< HIDEPRECISION set to 0 >>"))
    thanks a lot!!
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Ahh nice one - I think I perhaps wrote it a bit too quick
    Thanks for the compliments
    Updated my original code to sort out that typo
  1. Plot filename and date at the end of each plot
    By sadhu in forum AutoCAD Beginners' Area
    Last Post: 20th May 2010, 03:32 pm
  2. Plot Device/Plot Settings Tab
    By Rudbeckia in forum AutoCAD Beginners' Area
    Last Post: 11th Mar 2010, 03:33 pm
  3. Changes to plot layout and plot file for publish
    By GliderRider in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2009, 09:48 pm
  4. Plot with plot styles
    By Lucas_ in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2008, 05:30 am
  5. plot file locations for batch plot?
    By Kate M in forum AutoCAD General
    Last Post: 29th Oct 2003, 09:43 pm
